M35 Aluminum Under Tray - Test Fitting
Ilya
I prefer to say that I'm happier than a camel on hump day.
HUMP DAY!!! YEEAAAAAHHHH!
calidoso
Car: 2009 Infiniti M35x: 100% LED
Just ordered mine, how long till i should be expecting it to come in?
svard75
Car: 06 M35x
IlyaKol wrote:I prefer to say that I'm happier than a camel on hump day.
LOL I reserve that term for two other reasons. The first is when it's a Wednesday and something great happens the second is when my wife and I ..... you get the picture :rotflmao
@calidoso - You should be receiving an email notification from paypal with an update including the tracking number.
calidoso
Received my tray yesterday,
This might sound dumb but before I get into something not knowing, I'm assuming its just remove and install?
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
haha, yes simple remove and install. then tell your wife you have to "test" it out and will be gone for several hours
calidoso
Haha definitely
svard75
Car: 06 M35x
Installed mine today. First I had a few clips that had broken free from the plastic so I had to clamp the clip down then remove the bolts. That created an issue while installing the new unit since there was nothing left to put the new clips onto. So I actually have 3 holes without screws. The remaining were a pain to install as I was working under the car being on jack stands.
I strongly recommend you do this under a lift and expect to have broken plastics. It may be better to pick up used plastics from a junk yard before undertaking this. These are all car issues.
The part arrived quite quickly and in excellent condition. Packaging was quite meticulously done in a type of shrink wrap then into a cardboard box. No scratches. I strongly recommend buying the additional hardware kit because my bolts could not be reused. They were so rusted and the clips were ready to snap.
The piece looks amazing after install. Even though I have 3 bolts not installed there were no noises generated and I drove about 1 hour on the highway. While I had the old one off I took the liberty to spray asphalt undercoating everywhere. I also found my block heater cable and plug. I then sprayed graphite grease on all the suspension bushings and closed it all up. Just getting her ready for a LOOONG winter.
Ilya
Yeah I'm missing some holes too (all of my radiator bolts for example snapped off lol). Living in the northeast SUCKS...weather wreaks havoc on the car.
tollboothwilley
No humidity is nice - but the high heat we get here in Vegas can be downright miserable at times.
fat3oy
Car: 07 M35X, 06 350z, 06 RSX, 99 Dajiban
I have not read the whole post - but worked with you tollbooth on the tray for my car...
Just a heads up (you may already know) the tray is not plug and play for X model vehicles... I made mine work... but just a FYI. The front half shroud is perfect - the under sway tray is way off.
tollboothwilley
Did you get the M35x version? Cuz the RWD and AWD versions at very different
fat3oy
rofl - I didnt kno you had an awd version - we talked for forever near january before lol... def got rwd version... is all good
tollboothwilley
AWD version was just released not too long ago
fat3oy
ahh... that is why - again no worries - have a plasma cnc - made the nec adjustments - good to go
tollboothwilley
Take a look at the previous posts and you will see the different design. Let me know if yiu need one
fat3oy
will do man - love the tray regardless.
will be disappearing soon as I will have charge piping running lower than it sits - gonna english the one I bought from you to try and bulge it out a bit.
tollboothwilley
Mmm. Boooooost
njjuliano
Car: 2010 M45X
Just to add my interest, want to order for an M45X. Did we ever get the rattle situated?
tollboothwilley
yes for the M45 - haven't tested any on the M45X. So few out there dunno if the chassis is the same as the M45, or the M35X, or neither.
kmiles
Car: 2015 Q70 3.7 AWD - Hermosa Blue
Sold - 2007 M35x
Do you have any left for the M35x? How well does the black coating hold up?
Thanks!
jhuerto23
Car: 2006 Infiniti M45
Am I missing something here? I don't see the cost of this thing. Can somebody tell me how much this is?
:gotme
tollboothwilley
I have them listed up on the website
here>>> http://www.tollboothwilley.com/#!infini ... tray/c1z69
svard75
Car: 06 M35x
Anyone here experiencing rattling? Did you install it with some rubber isolators? Also Aluminum to steel causes galvanic corrosion should we perhaps have a pad between?
tollboothwilley
where are you getting rattling from?
Ilya - you have been running for a while - are you getting rattling at all?
Ilya
Nope, no rattling. Even trying to bend it by hand when under the car it doesn't budge.
EniGmA1987
Car: '06 Infiniti M35 Sport
svard75 wrote:Also Aluminum to steel causes galvanic corrosion should we perhaps have a pad between?
They have to be electrically conducting from one of the metals to the other for that to happen. While our cars do use the body as a ground path back to the battery, that area down there is not really a place that would ever be the quickest path back, so electricity wont be flowing from one area of the body (steel) through the plate (aluminum) and then back into the body just to get back to the battery.
svard75
Car: 06 M35x
I'll have a closer look on Monday. Enigma don't forget I live where they salt the roads. Salt+snow=electrolyte.
tollboothwilley
I ran mine in salt lake for many years no problems. Salted roads all winter long. For what its worth. I haven't heard of any person having issues
svard75
Car: 06 M35x
Great news TBW. RE rattle, I'm hoping it's my exhaust tbh. I know my flex joints were already leaking perhaps they broke :0
calidoso
Finally got the time and decent weather to install the Under tray. Didn't have access to a lift so had to do it with jack stands. Definitely way better that the crappy OEM splash shield.
