Wow that does not sound good. I drove a 2017 SV with 50,000 miles yesterday seems to drive OK. It also came from rental fleet.AZhitman wrote: ↑Mon Feb 04, 2019 10:18 pmYou'd be surprised. Stick around and do some reading, we've got plenty of horror stories.
BTW, if you buy a car from a rental fleet, you've shot yourself in the foot already. They're disposable, abused, and patched up for the uninformed buyer.
Also, an ATF cooler isn't relevant for a CVT. CVT fluid is nothing like ATF, and it has a very specific temp range - above or below and you're calling for a tow truck.
Rogue One wrote: ↑Tue Feb 05, 2019 7:04 amLike any good product, the vehicle should sell itself. If you have to be talked into buying it, then it's not the right vehicle for you. My advice? Buy something else.
CVT: Vibration while accelerating
Nissan CVT rant - from the people who know them best.
POLL: Would You Buy Another Nissan?
I AM DONE WITH THIS BRAND!!!--- Rant!
A percentage of Mitsubishi is owned by the Nissan-Renault alliance. I had a Mitsubishi Outlander as a rental when my Rogue was in the body shop under an insurance claim due to some sociopath vandalizing it and the Outlander was lifeless. You'd be better off with a Rogue than the Outlander, since the Rogue is more reliable than the Outlander.waid302 wrote: ↑Tue Feb 05, 2019 7:53 amRogue One wrote: ↑Tue Feb 05, 2019 7:04 amLike any good product, the vehicle should sell itself. If you have to be talked into buying it, then it's not the right vehicle for you. My advice? Buy something else.
I was also considering Mitsubishi Outlander or the Sport version. However, Mitsubishi also uses same Jatco CVT8 transmission so I assume it will have same issues as well.
Waid
The SAs over at the Nissan dealer in Coral Springs was surprised that I didn't do my CVT fluid change at 30k miles. The SAs over at Reed Nissan in Orlando told my dad to change every 60k miles.casperfun wrote: ↑Sun Feb 10, 2019 2:13 pmWow, just a decade ago it was known as lifetime fluid in the Nissan CVT.
Now your suppose to change it every 25,000 miles? Almost comparable to doing a long oci for your motor oil.
Gets me wondering if transmission oil should be changed every 6000-7000 miles and motor oil every 25,000 miles would be better since the transmission always goes first before the engine does.
Wouldn't be surprised if a Nissan vehicle would last longer that way considering the CVT history on these cars.
Interesting.![]()
Thats sounds about right where the stealerships recommend to "change" (flush) the CVT fluid around. 60k miles/100k kilometers. How many kilometers is on your Rogue? Since you live in Montreal, with harsh winters, its better to do a D&F now instead of a flush. The D&F takes half the amount of a flush.Maximus099 wrote: ↑Mon Feb 11, 2019 3:11 pmGetting all kinds of info myself. Called three dealers here around Montreal and two tell me not to change the cvt fluid unless its required depending on what the "computer" tells them and the other says to change it at 100k km. Called Nissan Canada and they tell me to rely on the two dealers and change the fluid only when its "required".
Hi John. I am also from NY, to be exact from Brooklyn. I recently leased Nissan Pathfinder from Nissan lease deals Brooklyn. It costs me $ 299/month. They have quite a wide range of Nissan, there are 2019 Rogue and Rogue Sport models too, so I advise you to look there.JonhG wrote: ↑Thu Mar 14, 2019 4:41 pmHi guys, I'm also aiming to buy a Rogue soon, but I'm looking at a newer 2019 version . Maybe someone here can share their experiences? Starting from the place of purchase and ending with experience in operation? I'm from NY, we have a local lease deals , at the moment it is one of the few options I have found. Maybe someone will offer other options.
let me show off our MY2014 rogue, awd, original engine and cvt, 212kmiles. I don't know what we have done wrong (apart from drain and refill fluid and replacing filters), but it works. yes, it is not perfect - but it works.vra wrote: ↑Mon Dec 29, 2025 10:51 pmI'm not a fan of rogue CVT''s 2014+. CVT8 is a massive downgrade and I haven't seen it last nearly as long as CVT2 (RE0F10A) or the better version CVT3 (RE0F09B). As a rebuilder, all the Rogues that come in to my space are OBLITERATED. Valve body completely un-salvagable. forward clutch, belt, pulleys, probably torque converter too. id get an older one and budged for a rebuild around 200k miles. Rebuild right and it'll last forever. CVT8 is mega touchy about bad oil.
If you're wanting to go to the safest option for CVT, 9-14 murano for SUV. 3.5L got the RE0F09B that year.
