Whoops, that sucks. At least its just another bend and another hole to drill in the bracket.sx moneypit wrote:I don't think i am going to have to notch the bumper support,i just need to raise it about 2 inches to get a little more ground clearance.I was thinking the bottom of the bumper cover was lower than it is.
I couldn't get my damned manifold on the studs last night, the holes weren't wide enough on a couple. I could get just the top or just the bottom holes lined up, but never all of them. I even tried torching them. Then I tried to drill them out but the stupid bit kept getting snagged. Finally I said 'eff it' and broke out the Dremel. That should fix it. Also took the time to gasket match and port the exhaust.
Still need to run my boost controller into the car and plumb my wastegate lines.
