Yeah I plan on porting the runners so they flow into the runners instead of just having a circle against the square port haha.neverlift wrote:let us know about that manifold, I want a cast mani...also when it gets in let me know if the ports are round or squared off? pic looks round, ka is squared..
aw man, i guess it's just part of being human everyone makes mistakes..knowing me i will probably end up doing some stupid s***/stunts later down the road. As much as i will try and avoid it I just know myself all too well lolmotoman399 wrote:i flipped it backwards. i was champ on wheelies and stoppies. about 20 min before my wreck i did about a mile long wheelie. it was weird cause from the second i pulled it up till the second i hit the ground i dont remember. it seemed like it just went straight back, like i never let off the throttle. im sure your fine spooled just keep it on two wheels.
PM'd you, I got one.Chris28 wrote:Technically I only need the one on the bottom in that picture, I grabbed the top piece off my auto driveshaft so I'm assuming they're the same. The only pick-n-pull type yard around here has no s chassis right now
I found that piece locally, but I am interested. How much do you want for the one piece?SiDwAyZ240 wrote: Chris, if Biggie don't have one like he thought I can hook you up. I got a 1 piece sitting a box and this would be the perfect excuse to swap it out.
I know I keep saying this...BUT...a few extra lbs of fuel pressure will let you run at a lower duty cycle. Personally I've never really worried about duty cycle, so long as they weren't operating at 100% all the time. Even if they see 100% for a few seconds, I doubt it will be enough to lock one open or closed.Chris28 wrote:Quick question - My wastegate currently has 15 psi worth of springs in it. I'm running 550cc injectors. I'm running a Holset hx30. Will I be maxing out my injectors at 15 psi? I'm going to datalog once I get it running but if I'm definitely going to be over 80% duty cycle I'd rather change the springs to 10 psi while everything is off the car and accessible.
