btw, good luck in tampa, ive read some of the post of problems youve had.hope it turns out goodFlorida240sx wrote:Hopefully I drive down to tampa saturday and get mine tuned... I'm running the IAP kit. What you doing for management, and what's your goals?
It's a Turbonetics T3/04 .50 Trim .63 A/R, and S13 hot cams. I'm looking at 375 to 400 hp. It's also a daily driver so it has to be civil. That's a Unorthodox underdrive waterpump pulley used in conjuction with a Nismo thermostat and Unorthodox underdrive crank pulley.GlacierFreeze wrote:Looks nice. What cams and turbo??
All told, I figure around 1,200 for the machining and rebuild of the long block. Add in all the internals including timing assembly, pistons, rods, ARP studs, gaskets and bearings figure another 1,600. You can get a kit from AMS or IPP, but it'll all come out around the same unless you got some super connections. I pieced it together myself and ended going to a number of sources and had to change form Aria's to Wiseco's mid stream. It took a real long to get all the parts together. I had a donner KA block with 79k on it which I got for 500. For all the other goodies, including turbo, manifold, down pipe, wastegate, BOV, FMIC, fuel management stuff like fpr, Walboro pump, fuel rail, injectors, ss hoses and fittings you're looking at close to another 2-3,000. You can do for less if you cut corners and go with cheaper or used products. It all adds up and no it aint cheap. The list can go on, cams, new flywheel, clutch, e-manage, gauges, wideband... and so on... and on...crash n’ burn wrote:dang
how much did all of that block work cost you, boring, honing..crank balance..etc
That's kewl... Good luck to you. I'm really not trying to recreate the wheel here, I just want a good reliable motor that will kick some ***. So as much as I rather not be spending tons of money on this build up, I'm committed to it.DRFT(kinda) wrote:Dude, you are running damn near the same setup I'm building right now. Minus the work done to the crank and the shiny-ness. Same turbo kit, same pistons, same ECU. Kinda funny. Today was the first day of the engine build and we got done all the way up to the cames.
haha its cool man. I was kinda worried when you said .052 ring gap.Kaleo55 wrote:Yes you are correct sir... I seriously typoed... pardon my error...
