RobDET »
https://forums.nicoclub.com/robdet-u7114.html
Sun Jan 05, 2003 5:21 pm
It's 240 HP... heres the list of stuff you need for the motor( The formula atlantic one from toysport
TOYOTA FORMULA ATLANTIC 4AGE
ORIGINAL TRD USA FORMULA ATLANTIC PARTS
The Toyota Formula Atlantic engine was developed by TRD USA. Based on the popular
Toyota 4AGE engine- the Formula Atlantic Sports Parts were designed exclusively for
RACING. The specifications and parts represent the ULTIMATE set-up for the 4AGE.
TOYOTA FORMULA ATLANTIC 4AGE PARTS PRICE EACH 11121-FT001 Intake Valve Guide $ 23.00 11125-FT001 Exhaust Valve Guide $ 23.00 11131-AE801 Intake Valve Seat (33.12 mmOD) $ 8.00 11131-FT001 Intake Valve Seat (+.005) (33.28 mmOD) $ 8.00 11135-AE801 Exhaust Valve Seat (29.62 mmOD) $ 12.00 11135-FT001 Exhaust Valve Seat (+.005) $ 12.00 11135-FT002 Exhaust Valve Seat (+.014) $ 8.00 17173-AE801 Exhaust Manifold Gasket 1.5mm $ 11.00 13501-AE881-D Intake Camshaft $ 720.00 13502-AE881-D Exhaust Camshaft $ 720.00 13523-AE801 Camshaft Timing Pulley $ 42.00 13711-AE802 Intake Valve $ 46.00 13715-AE802 Exhaust Valve $ 46.00 13735-FT001 Valve Spring Seat Platform $ 10.00 90913-FT001 Valve Stem Seal $ 6.00 26945-FT003 Inner Valve Spring $ 45.00 26949-FT003 Outer Valve Spring $ 45.00 13741-FT002 Valve Spring Retainer $ 16.00 13741-FT003 Valve Spring Retainer (Titanium) $ 22.00 13751-FT003 Valve Lifter (Bucket) (Standard) $ 48.00 13101-FT031 TAC Piston w/Pin, Clips, Rings STD $ 322.00 13101-FT032 TAC Piston w/Pin, Clips, Rings +.005" $ 343.00 13101-FT033 TAC Piston w/Pin, Clips, Rings +.008" $ 357.00 13031-FT001 Ring Set, TAC Piston, Std $ 41.00 13031-FT005 Ring Set, TAC Piston, +.005" $ 68.00 13031-FT006 Ring Set, TAC Piston, +.008" $ 68.00 13252-FT001 Clip, Wrist Pin Retainer (Replacement) $ 4.00 13201-FT002 Connecting Rod TAC - w/ Bolts $ 446.00 13265-FT001 Bolt, Connecting Rod Replacement $ 65.00 13251-FT003 Pin, Wrist Pin Replacement $ 40.00 13401-FT001-A Crankshaft (Atlantic Series Spec) $ 5,358.00 90105-FT040 Flywheel Bolt (Swift 008a) $ 7.00 11410-FT001 Engine Main-Cap Set (Steel) $ 327.00 15194-FT001 Front Cover Gasket (Metal) $ 9.00 11383-FT001 Rear Housing Gasket (Paper) $ 5.00 13568-FT001 Timing Belt $ 38.00 THESE ARE RACE PARTS ONLY. NO WARRANTY.
