idahotuner »
https://forums.nicoclub.com/idahotuner-u69417.html
Mon Nov 12, 2007 7:40 pm
Oh guys here is the pics from working on my car tonight, i got the head back on, but that is minus the cams and cam gear and other stuff. just the head, head studs, headgasket.
here is my 1.1 mm apexi headgastket
and here is my block all prepped for the head, nice and clean perfectly flat.
here is the bloc kwith the arp head studs installed. at this point i torqued them to 20psi. not sure if that number was correct but all the other numbers were for the actualy head torquing part.when i install the head the chain was in the way and we didnt notice it the one end wasnt going down and my dad was like tighten it a little bit to see if it sucks it down, nope nohting , so we hit it a little with the rubber hammer still no move ment then i realized what it was and we had to undo al lthe head nut and lift the head back up.here is the head on the block i tightend the head studs 20-40-60-80 working my way out from the center. basically backwards of taking the head offi used copper spray-a-gasket on the head gasket befor i installed it. nice even coating. i should have took a picture.another angle of the head on the block. make the block look liek crap with such a clean head. lol
now on to the other thing i did tonight finishing up my valvecover.i pianted the head bright green and then sanded the green off the letters.did the same thing with the spark plug coverhere is the spark plug cover all donethe vlave cover all done.yes my dad told me to mask off around where the oil cap goes but i will just sand it off.this pic give you a better veiw of the actual green color.
and here is the engine bay all painted. the picture is a little fuzzy.
and lastly the intake manifold studs. you can see the bent on on the left compared to the one on the right.
