idahotuner »
https://forums.nicoclub.com/idahotuner-u69417.html
Thu Nov 01, 2007 4:49 am
well i am finally getting around to pulling my head to night so i can take it into the machine shop tomorrow. the guys siad you dont hot tank aluminum heads. they pressure clean them with hot water. e said he isnt even sure if he will have to deck it if the head isnt warpped. which it shouldnt be, because i am taking it off wit hthe motor cold and falling the head removale thread. he will install my new vavle seals and new springs, check lift and stuff for my cams.
i kinda wanted to do this part to say i did it. but i dont have all the right tools. and it is worth it for me to pay to have it done right, cause i am a NOOB if he wasnt doing it over the weekend then i could see if i could come and watch while he did it. but i got other stuff i got to take care off.
it will be a relief when this part is done and back on the block cause. this is the most time important part of the build i think. and it should hopfully just be an aray of bolt-ons after this.
next i got to extend the wiring harness so i can tuck the wires under the intake manifold. that shouldnt be too hard. it is only 10 wires. 8 to the injectors and 2 to the O2 sensor.
well i guess this thread has turned into my build page as well. might as well up load soem pics on here too.
