Spray some WD40/PBlaster around them, let it soak, and pull them out with pliers...idahotuner wrote:ok guys i need input on how to tak e my injectors out and not destroy them in the process.
What injectors and what FPR did you end up using?idahotuner wrote:you an me both WC. and that can be the only place i am having a problem because fp is set low and it is still flooding. and plus it take the fuel pump forever to pressurize the system. which makes me think it is cause it is leaking around the injectors as well.
how can i get the injectors out without damaging them though?
Top feed OWNS!! no need to struggle with those things at all lol.codyace wrote:That reason alone is why I always suggest top feed injectors and rail....so much easier to remove....
that is waht i am heading out to do now. i will hopefully have pics.duffman1278 wrote:
Anyways, did you try the method I told you about? any more pics?
i should have said with the coil pic that iam gettign new RUCAS from PBM as wellduffman1278 wrote:Time for new rear suspension arms!
Is that the boot for the clutch operating thingermerbobber?idahotuner wrote:and one havea part number for this boot?
well i kinda have a problem when i put it together the right way the camera was dead. so i dotn really have any pics. so if i can just go in and reword it then i will do it soon and if not then i will pull it apart for the 2 more pics i need lols14tan wrote:hey did you ever fix the short shifter write up?
