3" of hg? .....
I'd def want to get checkin on that timing...
I can remember building an engine once and lining up the links on the bottom wrong (my mind was off that day and placed TDC in the wrong spot). Car fired up, ran 'ok'...had issues ideling and the sort....and wasn't pulling much vacuum.....I went to set timign and we couldn't get the CAS to even get near 15....thats when I knew we had an issue.
As far as the car revving higher with vacuum lines off, that is hit and miss with domestics in my experience..SR's tend to want to idel lower and rougher....
Not saying its' a must, but def check otu
http://www.blazt.biz and look into their NissanDataScan and cable. Invaluable tool.
Does it seem to rev at all or no?
