I'm New Here And I have A Simple Question Thread, (No Flaming Allowed)
d0pe240
can anybody help me out with this still please? Just got my first set of coils. They are cusco zero 2E and I'm having trouble lowering them. These are used and they didn't come with instructions. I've messed with the prechers by moving it up a little bit, then locking them. Then lossen the lock collar on the bottom and moved the whole coilover down, but still the height stays the same on both sides of the front. I haven't done anything to the rear yet. So if anybody can help me out please? Also how low can the zero 2E lower the s13? If anyone has pictures, can they post it up please? Thanks alot.
DJButton
Car: 2010 Nissan 240sx
Moving the lock collars down a bit should bring the springs down.... you are adjusting them on the car right? I'd like to commend you on buying really good coils for your first set but on the other hand beware of used ones! Seriously, they might be ready to blow.
Pyrokid
Car: 2000 Honda Accord, 1990 Sr powered 240sx hatchback
Ok, thanks alot, I'll replace that soon, and take your advice and get a new slave cylinder.
d0pe240
thanks man for the reply. yeh im adjusting it from the car. i looked at all of the coils and theirs no oil leaking anywhere. i was wondering tho, about the ride, wenever i go over this one highway, it seems to bounce. the dampening is set at 2 (5 being the hardest), but is it the coils or the road. on other roads their pretty smooth. just want to be sure its not the coils. they seem to be pretty stiff too, are they like that?
Kckouki
Car: '97 Nissan 240SX
Hey guys ! Im a newb to the forum, wheres the search button at ?
PapaSmurf2k3
Site Admin
Kckouki wrote:Hey guys ! Im a newb to the forum, wheres the search button at ?
We don't make one for your "type"...
got chub
Car: pearl white 95 240sx
i know on my bike i had a chrome tip and after a few months of hard riding and the occasional race the tip started to turn.
OCHOcinco
Car: 1990 240sx
hey im new here....i gota 1990 240sx with a red top sr20 swap ....my problem is....sometime when im put in the clutch or pop it into neutral my revs drop really low almost to the point of stalling then go back up....what could be goin on
Modified by OCHOcinco at 1:57 PM 10/28/2007
jh3xp
Car: 1992 240sx SE Coupe
Another dumb question from me sry. umm... i recently changed my spark plugs and spark plug wires....and then i noticed that everytime i drive that some of my spark plug wires pop out of the hole...not the whole tube but enuff so its not firing....is this due to it being the wrong spark plug wires? cus when i was taking them out and putting them back in i did notice that they were harder to take out and seemed like it was geting stuck on the way up.
Zippy69
Car: 1993 240sx coupe
Did you lube them with some silicone spark plug boot lube?
jh3xp
yes i did... i only lubed the tip tho is that right? i mean they only give u so muchbut that shouldnt be the reason they are popping out like that
PapaSmurf2k3
Site Admin
OCHOcinco wrote:hey im new here....i gota 1990 240sx with a red top sr20 swap ....my problem is....sometime when im put in the clutch or pop it into neutral my revs drop really low almost to the point of stalling then go back up....what could be goin on
Well, if it is happening after kinda pushing the car (ie... being in boost), it is probably because you have an atmospherically vented blow off valve, which is blowing off metetered air.
Beyond that, I dunno (I'm not an SR20 guy)
PapaSmurf2k3
Site Admin
jh3xp wrote:yes i did... i only lubed the tip tho is that right? i mean they only give u so muchbut that shouldnt be the reason they are popping out like that
what kind of wires? Usually if wire fitment is correct, and they are popping out of the holes, it is because the spark plugs aren't in all the way, and air is getting by them, which pops the wires out due to their semi-tight seal.
I would immagine if that were the case the car would be running worse than before, and you would probably smell fuel too.
jh3xp
kool thanx im pretty shure its becus i didnt tighten my spark plug wires enuf. But why is it so hard to take out? ehh
PapaSmurf2k3
Site Admin
cos you are a girly man?
Once again... what kind of wires do you have?
jh3xp
haha
oh yea sry i think it was bgw or sumtin like that.
PapaSmurf2k3
Site Admin
never heard of them. If they were cheap enough for you to not care about, I'd pick up some NGK blues.
http://www.sparkplugs.comNICO sponsor
jh3xp
Thanx alot, but ill try ur original advice first and tighten the spark plugs.
OCHOcinco
Car: 1990 240sx
ah ye i think ur right i member hearin somethin bout that ...thanks alot saved me a lot of worry
jh3xp
Soo yea...as i take out the spark plug wires to tighten my spark plugs..... the rubber tip from these damn cheap pokemon quality bogus *** spark plug wires come off. So the rubber part that contacts with the spark plug is stuck in there and i cant even get my socket over it to tighten the spark plugs. what should i do? ( by the way this happened to all 4 of my spark plug wires)
DJButton
Needle nosed pliers should get in there to pull the rubber out, or try a pick if that doesn't work. You'll def need new plug wires too.
jh3xp
On the real man, no more ghetto made spark plug wires. Needle Nose pliers wont reach tho :/
PapaSmurf2k3
Site Admin
buy extra long ones... they make them.
Justin VanWinkle
Car: '91 240sx FB(Looking for LS1)--- '92 240sx FB--- '93 240sx FB(DD)--- '04 RX-8--- '03 SV650(Track)
Sounds like a personal problem to be, boy...
I couldn't pass it up.. I'm sorry hahahaha
jh3xp
LOL everythings fine and dandy down there
on the serious note
used a shishkabob stick and sum long needle nose pliers and got that **** out....but juss put it back cus i cant find my reciept lol but atleast i got to tighten my spark plugs
RCG_Savage
Car: '92 240sx fastback
Is there any way to tell the difference between a s13 and s14 ka24de distributors?
qat727
RCG_Savage wrote:Is there any way to tell the difference between a s13 and s14 ka24de distributors?
Yes. The most obvious difference is that the S13 uses an external coil, whereas the S14 uses an internal coil.
giodachamp
Car: Nissan 240SX S13 (180SX)
Is it true that if you have a aftermarket header, you can't pass California's smog check?
PapaSmurf2k3
Site Admin
giodachamp wrote:Is it true that if you have a aftermarket header, you can't pass California's smog check?
I beleive the law is that it is illegal to modify the stock exhaust in any way... which would fail you on the visual. As far as smog goes... I don't see why it would make you fail that unless you had a catalytic converter in your header that gets replaced with straight pipe when you go to a header.
giodachamp
PapaSmurf2k3 wrote:I beleive the law is that it is illegal to modify the stock exhaust in any way... which would fail you on the visual. As far as smog goes... I don't see why it would make you fail that unless you had a catalytic converter in your header that gets replaced with straight pipe when you go to a header.
ok thanks.. one more question, since you said you would fail the visual part... can you just hide the aftermarket header beneath the heat shield since it has that in the first place, or is it because it wouldn't fit?
