what are you talking about? vented covers?theres 2 different type of lights on the kouki 180sx...JDM-Silvia wrote:Anyone know where I can order or get the OEM vented covers? the foglight by itself won't look right.
if so, as far as I know, theres none made. Should be tho, but no, I've never seen one made for the market, just home made ones.Scuffed_ChukiCoupe wrote:i belive he is talking about the usdm covers where the drl's go.
I thought he was still on the topic of foglights... lolanyways, I have a pair for saleScuffed_ChukiCoupe wrote:lol... he is talking about the oem nissan chuki bumper grilles. The little grilles that screw in under the bumper lights.
electic fan isn't necessary if you still have the clutch fan. Also, consider the 255lph fuel pump instead of an oem one, and get the z32 fuel filter, its only like $10. And make sure you get the sr tach, and not the ka dohc tach, theyre different.gordonliu wrote:i know this question has been answered to different degrees.
ive found threads that discuss it.
i still have a qestion
sr swap into sohc s13 parts needed:
front clipnew rad (NEW or stock sr)hosespower steering lines and res(at minimum) from dohc (or pump, res, and lines)electric fanfan controllerdownpipemaf adaptorfilterspark plugsfuel pumpDOHC tach .
sounds like your synchros are crappin out. when was the last time you changed your transmission oil?jh3xp wrote:My car sometimes grinds going into first, unless you push the clutch pedal up because it sags or something. And recently its been reallly hard getting into gear. what should i do?
Thats what I was talking about. I couldn't think of what they were called at the time. How much do you want for your Adrian?Scuffed_ChukiCoupe wrote:lol... he is talking about the oem nissan chuki bumper grilles. The little grilles that screw in under the bumper lights.
email me at [email protected]JDM-Silvia wrote: Thats what I was talking about. I couldn't think of what they were called at the time. How much do you want for your Adrian?
FYI, I think 1st gear isn't synchronized, but definately look into changing your transmission oil, maybe go synthetic. How does your clutch feel? If it is weak, you might want to look into the hydraulics and see if you have any leaks anywhere or something.jh3xp wrote:My car sometimes grinds going into first, unless you push the clutch pedal up because it sags or something. And recently its been reallly hard getting into gear. what should i do?
thank you very much i will definatly change the transimission fluid also just wondering whats the differance in synthetic and normal oil? also fixing synchronizers would that be cheaper just buying new synchros and fixing it yourself at the school shop(with the aid of like a teacher) ? or is that something thats hard and i should take to the shop.PapaSmurf2k3 wrote:FYI, I think 1st gear isn't synchronized, but definately look into changing your transmission oil, maybe go synthetic. How does your clutch feel? If it is weak, you might want to look into the hydraulics and see if you have any leaks anywhere or something.
Perfectly doable. The ring lands are the common breakdown from what I hear on the KA.Th1nk wrote:I want to boost my s14 to get 275hp, do you think i can get away with doing it with stock internals?
compression is 170 in all four cylinders 123,xxx on engine.
Yay NEWBIES!
synthetics usually claim they are better for the synchros. I have been using redline in my transmission and none of my gears grind. As for fixing synchros: I have never done it, but since you basically have to take apart your transmission I'm guessing its going to be a huge pain in the ***, and if you do it in class you are going to have a lot of downtime cos you can only work on it what, maybe an hour a day?jh3xp wrote: thank you very much i will definatly change the transimission fluid also just wondering whats the differance in synthetic and normal oil? also fixing synchronizers would that be cheaper just buying new synchros and fixing it yourself at the school shop(with the aid of like a teacher) ? or is that something thats hard and i should take to the shop.
