hmmm I never thought about that. I ll probably leave them in until I get a cage. Thanks for your helpPapaSmurf2k3 wrote:It might also add some structural rigidity to the chassis...
I have no idea what you meant by "stainless steel (thinner) as source), but the only way to fix a leak is to, for lack of a better word, FIX IT. Find out if it's a gasket, or if it's actually a crack in something. If it's a crack, it can be welded. If it's a gasket, take off the original, clean it up with some brake cleaner and a putty knife, and replace it.Brownskills wrote:hey,
Just recently installed budget headers and down pipe. Noticed the gains, but exhaust don't sound right. I told mechanic it felt like a leak, after testing he said that its stainless steel (thinner) as source. Notice exhaust smell strongly from engine, noise is comparably louder.
I feel its a leak, any ideas? on how to fix this.
thanks
So it doesn't even matter if its from an s13 or s14?PyR0NiAk wrote:Transmissions are the same...
No, it doesn't matter.speedracer72 wrote:So So it doesn't even matter if its from an s13 or s14?
I was almost certain they did... are you sure you don't have one on your car?alfsnissan wrote:Did all S14's come with rear sway/stabilizer bars? I see it in my FSM but....not on my car. What the heck?
Positive. There are the holes in the lower control arms where the connecting rods would go but....no sway bar.PapaSmurf2k3 wrote:
Yeah, I did a little hard searching last night and am seeing alot of people who don't have a rear sway bar. Something about the base models didnt get them for some reason.OutToWinPAHC wrote:All S13's came with rear sway bars, but not all S14's. I don't know why that was but I have heard it from others. I think a J30 sway bar will also work if you cant find a S13/4 one.
I am pretty sure they can be used. The J30 one does have an extra bump for dual exhaust, but other then that I think they are the same.alfsnissan wrote:
But your saying that a J30 and S13 will fit the S14 with no problem?? Thanks everyone.
I think the bottoms are the same, but I think the tops are different. Do the coupe seats fold down.CA18dragon wrote:Hello I'm new to the 240/180 scene I have a 1989 240sx hatchback that is being rebuilt with pretty much no money. So I hope to find the information I need on here. I hope to put a CA18DET in it.
Without further adue my first question is, can you put the backseats of a coupe inside a hatch? [Same year.]
yup, they do.OutToWinPAHC wrote: Do the coupe seats fold down.
