Depends is he lowering his car? If he is then yes you will probably have to roll your fenders.ALLout wrote:Hey guys. my buddy has a 94 Silvia rhd 5x114.3 and he now wants to change his wheels and tires to 18" I found some info but nothing to convince us to go foward. We found some pics of a s14 with rota P45r 18x9.5 +15.. im wondering if there are any chance this will fit without rolling the fenders. Then if he has to roll the fender, would 17" wheels be a better choice for him? + ive check on rotas site and they only make +12 offset with 18x9.5 5x114.3. USA vs JDM cars.. wheel fitment are they the same?
Your just going to have to drill the 2 holes for the bumper extensions.Alyx wrote:Hey, I have a dented up front passenger fender on my 93 HB, and I was wondering if anyone could tell me if a fender from a 89 coupe would look the same (or close) and fit properly on my 93 HB (besides the difference in the extensions).
I ask because there is a person parting out their Coupe near me, and I would like to replace this ugly fender.
Thanks in advance.
Well for starters, the DOHC is newer (put in 240s from 91-98), and more efficient (makes 155hp from 2.4 liters as opposed to 140 or 145 from the SOHC). The SOHC only came in 1989 and 1990 model 240sx'sspeedracer72 wrote:What is the difference between the ka24 dohc and sohc. Such as the years it was put in the car maybe. I plan on building a ka24det. Do the consensus of people build one over the other?
I'm pretty sure the ABS pads are different... but other than that I'm not sure. You could just ask your local autozone guy or whatever if they have the same part number.justinedible4 wrote:Will the brake pads for a s14 fit a s13? whether it be 5 lug or not?
I usually just use a wire brush, but if you use sandpaper, you'd start with something kinda heavy, and work your way down to something light (before painting).rootS13 wrote:What strength grit paper should be used for sanding off surface rust?
I'm pretty sure it won't have any effect on HICAS. As far as the drive shaft, I used my stock one. Hell you can even use a KA transmission if you swap the bell housing.SpecD_240sx wrote:So got a question about the good old SR swap. First of I got a 91 240 LE. I got a couple questions, first off, do you need to modify the driveshaft when swapping a SR into a 240, and also, is there any issue with having hicas. To my knowledge there isn't, but i don't really no for sure. My car is in great shape body wise, but the KA is gonna die any day now, so i'm looking at my options. I was also thinking about a 1j, but with school being busy as crap i got no time to look into getting into that kind of swap. Just looking for input, anything helps.
Thanks
I THOUGHT there was a thread about that somewhere on NICO, or maybe an article. Did you check http://www.240sxtech.com ?240saint wrote:my question is what suspension parts i can use from the z32, i need to know i have a buddy with a donor car and i may need to take the control arms and brake setup from it. so the question is what suspension parts can i use from the Z32?????
Its the metal that is on the shock tower. All i can see that it does is hold the rear seat.PapaSmurf2k3 wrote:could you maybe take a picture of what part you are talking about? I have a coupe, not a hatch, so I can't go out there and look at mine.
