Thank you, I looked at it again. Did stock koukis come with a blue light that turns on to show you your lights are on? It seems that this blue light is spliced into the wire that leads to the cigarette lighter, would this affect it at all?PapaSmurf2k3 wrote:Yeah, check your fuses. And yes, you can buy the entire assembly. It might not fit quite right, but you can buy one.
You could also yank one out of a junk yard.
That is kind of complicated. It is a pretty complex shape... not likes its just a cube of empty air under the hood.hatedinthemind wrote:S13 engine bay demensions? (width, length, and depth)
Replace them. Fastenal or other fastener places will be able to match just about anything.car nut wrote:Any suggestions on renewing old rusty bolts?
You can also try running them through a wire brush or wire wheel (like on a bench grinder) to clean them up if replacing isn't an option.car nut wrote:Any suggestions on renewing old rusty bolts?
You can use phosphoric acid. (please use safely) There are some rust removers out there, but I can't vouch for them. Wire brush works well, but if the rust damage alters the performance of the bolt, replace it. You don't want a bolt that the socket barely fits on or one with missing threads... I've replaced I don't know how many bolts. If you replace bolts, don't go stainless if it is structurally important, stick to steel. I'm a Class 8.8+ nut.car nut wrote:I considered replacing them but basically every bolt I have is at least partially rusty. I remember reading about some liquid you can soak them in in HOT ROD but I can't remember the name of it.
It just looks like you need to pull it out on the right side and work the left out. (see the clips holding the left in?)jgc731 wrote:how can i pull out this low beam bulb for s13 triple projector headlights? i didnt want to force and snap anything please help.
It looks to me like those things on top are spring clips... the same thing my Prelude uses. You might have to squeeze them one way or another, and then kinda remove them from a clip of some sort, and then they should swing out of the way, allowing the bulb to drop out.jgc731 wrote:how can i pull out this low beam bulb for s13 triple projector headlights? i didnt want to force and snap anything please help.
PapaSmurf2k3 wrote:You can set them however you want. Lower one side if you are doing circle track or something, lower/raise the front or the back, or you can keep them all even...
Could possibly be a wheel bearing or an issue with the brakes. How do the brakes feel otherwise?manafd wrote:Why is there a horrible knocking noise coming from my front right wheel? This has only started happening TODAY, it's a knocking noise while at speed and it gets reduced to a squealing noise when at low speeds. The noise feels as if it's only active at a certain point of the wheels revolution. help guiz, i be poopin =[
What are the odds you can get a video or sound clip of it? The wheel bearing is fairly simple, but I would want to make sure that's the problem before buying a bearing.manafd wrote:Brakes feel normal, though i've only had it for 2 weeks. And the wheel alignment seeems fine because it isn't pulling away to the right. Wheel bearing most likely do you think? If so is this a large repair job or is it fairly straightfoward.
