I found a good write up thanks! Is there any downside of removing it though?PapaSmurf2k3 wrote:You can remove your clutch box if you haven't done so already... that helps a little bit.
If you replace your clutch with one that has tighter pressure plate springs, the clutch should be slightly harder to push (I think).
I have no experiencing with bleeding hydraulics, how exactly would I bleed the clutch hydraulics without a vacuum bleeder?Also the write up says you can buy a separate clutch line instead of bending the stock one. Is this what they are talking about? http://www.enjukuracing.com/is....htmlInstead of bending the stock line you just attach it from the line that comes from the clutch master cylinder to the rubber hose coming from the slave cylinder?PapaSmurf2k3 wrote:the clutch gets a little stiffer... if you can call that a downside. Other than that, its nothing but good. Make sure you have a spare body available to bleed the clutch hydraulics when you're done (or buy a vacuum bleeder).
I'm f***ing stupid, would this whole modification even work if my car was converted from auto to manual?PapaSmurf2k3 wrote:And yes, that link you posted is for the clutch line so you don't have to bend your hard line. It connects directly to the slave (replaces the rubber line at the slave).
Pretty sure they are.rootS13 wrote:Well, I have a spare injector rack from an S14 so I dont need to buy new injectors. I was just curious if they were the same.
btw your link is missing the "s"
Thank you though.
Stock FPR should work, if not then yeah you might. Hubs, steel wool and degreaser.justinedible4 wrote:I was wondering if i install a Walbro 255 lph fuel pump on an ALL stock 91 s13, would i need a FPR (fuel pressure regulator to account for the increased gas?
Also does anyone know a good way to clean hubs while they are off the car?
Whatever it was from the factory. Off the wall colors only look good on certain cars. Hatchbacks tend to pull it off ok, but coupes look horrible with them.c-hood240sx wrote:yeah im going to fix the bumper and nah the paint is primer lol any good ideas on a nice color?
EVERYTHING, matches up. The only differences between a coupe and HATCHback are the obvious oneschefboyrp123 wrote:Hello everyone.... I currently drive a 180sx in Japan and I'm looking at building a stateside drift car... I have a sr20det sitting at my house stateside... I was wondering if there are any differences between the 240sx coupe and the 240sx fastback (other than the obvious)... It'd be nice to know whether or not i can send my lsd and cusco suspension from my 180 back and not have to worry about which 240 i get.... Thank you!
