I'm New Here And I have A Simple Question Thread, (No Flaming Allowed)
safin
I did miss it. I think the bolts are the same thread as the fender bolts but different length. try it.
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
Thanks will do.
bersh240
is there a thread around here about running front mount intercooler pipes without relocating the battery?cant find one...
sileghtychad
Car: 1989 nissan 240sx
hey, im new here, but i have pretty simple question about turbos that nobody seems to answer or want to answer, my question is: i have a sr20 black top with a gt2871r, its set at 10 psi, and i have a to4e that im going to set at 10psi that im getting ready to install. now i used to think that 10psi was simply 10psi, but now im figuring out thats not the case, the to4 will put out more power at 10psi than the gt23 will at 10psi, but why? if somone can pleas answer this for me or point me in the direction! THANX!!!
billabong093
Car: 1990 S13 Hatch
sileghtychad wrote:hey, im new here, but i have pretty simple question about turbos that nobody seems to answer or want to answer, my question is: i have a sr20 black top with a gt2871r, its set at 10 psi, and i have a to4e that im going to set at 10psi that im getting ready to install. now i used to think that 10psi was simply 10psi, but now im figuring out thats not the case, the to4 will put out more power at 10psi than the gt23 will at 10psi, but why? if somone can pleas answer this for me or point me in the direction! THANX!!!
So you thought that 10 psi is the same for all turbos...?
Uhh. If you think that, then you must think that all turbos are the same lol. Different size turbos put out different amounts of power. For example, a bigger turbo running at 8psi can make the same power as a smaller turbo running at 10 or 12. The bigger turbo is more powerful so it doesnt have to work as hard (ie, cranking up the boost) as a small turbo to make the same power.
Hope that helps.
TroubleBound
Car: 1992 240SX Hatch
How do you guys get motivated when you start to lose interest in your pos prject taking forever? I havent worked on my car in like a month nothing is keeping it from starting and driving but me not working on it. But i have a daily driver 240 coupe and i just haven't felt like going over there recently. It's smelly and cold and leaky it's a s*** garage but it's only 50 a month. That and i am always alone there. I just can't get my a** from off the couch or off my skateboard to go work on it.
Does this happen to you guys? What do you do to regain interest or get some motivation? I try looking at people builds on Nico for inspiration and at nice 240's but i just would rather look at them online then go get pissed off and cuss and scream and not get anything accomplished to my hatch./vent
bersh240
well...first you get a girlfriend...then you listen to her bi*** and complain about life and then she gets mad and starts yelling at you.then she asks you to go somewhere with her whiles shes pmsing..and you say. "oh sorry i gota get my car done"then your happy to work on it.
TroubleBound
My girlfriend doesn't ever have her period and i never notice if/when she is PMSing. She is almost annoyingly nice sometimes. She doesn't complain at all and goes with me when i go to the garage and helps out when she can. But she doesn't like the cold and hasn't asked to go there without me telling her we were going in months. Poor carI always joke and say i will burn it or crush it. Prob wont.
bersh240
hm.. well.. you could read teddys thread..im outa ideas.
Caveit77777
Car: 1996 240sx SE
My noob question for the day. Looking to buy a s13 but don't want hicas. How can I identify it so I can avoid it?
odmoht
ahhh...need some help.i got a CEL and i checked my ecu for the codes and i got 33 and 34.i think those two are the front o2 sensor and the knock sensor ???do i need to replace these two sensors?
got the codes from this http://www.240sx.org/faq/artic...h.htmoh and i have a 92 s13 with about 230k miles , if that matters.
any help is appreciated!
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
If you afr is off due to a bad 02 sensor the knocks emmisions will also be off. I would replace the o2 first.
UNDRGRND240
Hi, I'm about to buy a 240sx , 150K kilometers, (around 70K miles?) and I would like to know if theres any special things to check, if theres any general known flaws on this kind of car.Many thanks in advance
bersh240
rust. esp the frame rails strut towers. under doors. and if its a hatch with a spoiler theres bound to be rust there.
odmoht
OutToWinPAHC wrote:If you afr is off due to a bad 02 sensor the knocks emmisions will also be off. I would replace the o2 first.
whats "afr"oh and my Oil Pressure Switch is leaking oil...im assuming i would need a new one correct?
thanks for the help!
bersh240
afr= air fuel ratioand its leaking oil? wow. id say so.
odmoht
oh...icicwell yeah...i always see a little puddle of oil on the ground everytime i park..would there be anything else that would leak oil ? around that area i mean.
bersh240
is the oil filter tight?..
odmoht
yeeep.checked under/around the filter and all i got was some dirt, no oil.
PapaSmurf2k3
Site Admin
oil leaks are sometimes tough to diagnose. Oil can leak one place and then run along something and look like its coming from somewhere else.
Your front main seal could actually be leaking, and then it just blows backward toward that area. Pretty tough to diagnose over the internet really.
Caveit77777 wrote:My noob question for the day. Looking to buy a s13 but don't want hicas. How can I identify it so I can avoid it?
If it has hicas, you'll see all sorts of steering hardware back there. I'm also pretty sure a "HICAS" light will light up on the dash when you turn the key to the on position (and not start it).
PapaSmurf2k3
Site Admin
TroubleBound wrote:How do you guys get motivated when you start to lose interest in your pos prject taking forever? I havent worked on my car in like a month nothing is keeping it from starting and driving but me not working on it. But i have a daily driver 240 coupe and i just haven't felt like going over there recently. It's smelly and cold and leaky it's a s*** garage but it's only 50 a month. That and i am always alone there. I just can't get my a** from off the couch or off my skateboard to go work on it.
It happens a lot when you have another daily driver that doesn't completely suck. You can look at old pics of your car... or think about how screwed you'd be if something were to happen to your daily.
That's kinda where I am now. My DD needs some serious work done to it, so I gotta get the 240 ship shape in the very near future.
Dire91
Car: 1997 Nissan 240sx SE
Paint Question: A family friend has a body shop and paint booth and I want to get my front & rear bumper covers and side skirts painted. I'm not sure about how I should go in prepping these things. All of them are already painted items. What are the steps I should take with sanding, bondo etc... so I can have them ready for paint?
speedeast
Car: 1990 240sx VH45 FB & 1993 300zx
Dire91 wrote:Paint Question: A family friend has a body shop and paint booth and I want to get my front & rear bumper covers and side skirts painted. I'm not sure about how I should go in prepping these things. All of them are already painted items. What are the steps I should take with sanding, bondo etc... so I can have them ready for paint?
Well, all you have to do is sand them real good so some primer can adhere. 220-320 grit paper should be fine. You only use bondo if you have imperfections. If there are holes or cracks, they need to be repaired with fiberglass... if they're plastic, the need to be plastic-welded. So, sand, prime, paint. You may have to wetsand when you are done to perfect the clear coat, i use 1000-1500 grit for clearcoat imperfections.
Good luck!
odmoht
PapaSmurf2k3 wrote:oil leaks are sometimes tough to diagnose. Oil can leak one place and then run along something and look like its coming from somewhere else.
well...when i was looking for the leak.i saw oil coming out of the oil pressure switch, it was dripping slowly.
speedeast
Simple, it'll have tie-rod ends in the rear... as well as a rack & pinion. There is also a hicas light on the dash, and a solenoid under the hood. Here's a link, you'll find almost everything in a search:
zer...age=1
You can also google 240sx superhicas and find pictures of the solenoid, etc.
GaMBiTx
hi,i installed the rear strut/spring today and but i didnt quite understand the lower bushing part the fsm refers to..."When installing upper spring seat, ensure that larger inner diameter side of lower bushing is facing outside of vehicle and smaller inner diameter side of lower bushing is facing towards vehicle."
http://174.143.96.117/BIN/images/KYB/SM5154.jpg (right one is lower bushing)
Can anyone help me...im also using kyb108 strut boot...dont know if i installed it correctly cuz it ddid not look like what was on the the old strut/spring at all...thanks.
i installed it in like this pic, but i couldnt put the metal plate back cuz the bump stop on the boot was too big, please help!!! http://buykyb.com/catalog/images/KYB/sb108.jpg
Modified by GaMBiTx at 7:43 PM 1/15/2010
dabears_23
Car: 1998 Nissan 240sx LE
Hi im thinking about buying a digital climate control and a digital gauge cluster for my S14
I want this one
on ebay it says its for the S13 but will this fit on my s14?
i dont really like the other one, this one says for S14
but i will settle if installing the s13 one is not complicated
also
i bought a gauge cluster like this one, also labeled for an s13
i havent take the cluster down but is it just plug in the harnesses and thats it or what? that goes for the climate control too, is it plug and enjoy?
JurisMyDiction
Car: 89 Pignose COupe
I love this thread!
I'm getting custom steelies made. 16 by 8 in front and 16 by 10 in back. What offset will give me me a flush look with a stretch and pull. Either 195's or 205's ( /50/16)
PapaSmurf2k3
Site Admin
GaMBiTx wrote:hi,i installed the rear strut/spring today and but i didnt quite understand the lower bushing part the fsm refers to..."When installing upper spring seat, ensure that larger inner diameter side of lower bushing is facing outside of vehicle and smaller inner diameter side of lower bushing is facing towards vehicle."
The lower bushing (hole at the bottom of the strut) has 2 different sized openings in it (its probably got a lead-in cone type shape to it). Make the larger opening face outward towards the outside of the vehicle.
PapaSmurf2k3
Site Admin
dabears_23 wrote:Hi im thinking about buying a digital climate control and a digital gauge cluster for my S14
I want this one
also
I'm not 100% sure on this, but I'm pretty sure the S13 components won't fit in your S14. The dash and wiring harnesses (...and body panels) are one of the few places the 2 cars differ.
