2g00d4u wrote:Im still stump with this issue.
Im still getting a low idle when I am stepping on the brakes at a red light or reversing. On a cold start the idle is a bit jumpy around 700-800 RPM (Both in P and N position). Once warmed up (1-2 minutes), the idle is fine. It stays around 750-800.
Its just when Im reversing or at a light the idle drops to 500-600. I dont notice any loss of power.
What I recently done:
-Changed oil and oil filter-Changed fuel filter-Changed PCV valve (wasnt able to find any leak on the hose, may have to try again)-Cleaned MAF-Seafoamed crankcase and intake manifold-Put in some fuel injector cleaner (didnt use seafoam, not enough)-Checked plugs and wires-Replaced dis cap-CTS
The last time I checked for codes, I got 32 (EGR) and 13 (CTS). I reset codes the other day and the CEL came on again when im on the freeway and when I get off onto the streets it dissappears .
Anyway, I will check for codes again and hopefully code 13 is cleared up.
Wow, been busy lately. Some good news. I checked for codes and the CTS code cleared. I still have code 32 though.
Also, the last 4-5 days, the car has been idling somewhat better. Today was the most noticeable. I drove to school this morning and I noticed that while idling at a red light, the car doesnt shake much at all (compared to before). Idle hoovers around 600-650 though (compare to 500-550 where it felt like dying). Idle at P/N is still around 700-750, so thats fine.
I cant remember if the CEL came on after I reset the codes. I think it may have, but its most likely code 32 still.
I'll see what happens when I leave school later today.
I still havent changed the o2 sensor even though I bought one. Slacking big time. I hope it helps with my gas mileage. I checked my MPG with 2/3 tank filled and it was around 14.8 MPG. So full tank, im looking at around 15-16 .
