your fuel pump should stay on as a constant without change. and yes the pin could have broken off.GaMBiTx wrote:I have a similar problem with the Ka24E as you stated above. I took out each injector wire one by one, and cleaned the contacts and tightened it slightly using a small screwdrive I pushed the contacts so it would be tighter.
I still have the hesitation though, I can hear my fuel pump whirr up and down sometimes, what can cause this ?
I dont see my timing alignment pin, i see the marks on the pulley! could it be gone?
1. umm, yeah i think it is the throw out bearing .. cos when im in gear it doesnt make that noise .. only when i hold in the clutch .. THANKS Alot Problem SOLVED..240tunerguy wrote:1. is it clutch related? does it matter if its in gear? clutch depressed or up? a throw out bearing will make a similar noise. 2. if not pull off your valve cover and take off the timing chain guides. reinstall valve cover and recheck. they arent needed anyways.
1/ when you push your clutch in and out at idle the noise should change. if it does it could be your throw out bearing.JDM Sil4ty wrote:
2. im not a mechanic nor do i want to mess with the engine .. so your saying that taking off the valve cover and taking out the chain guides will not damage my motor?.. and reinstalling everything back on minus the chain guides .. etc..
no mods except radio, it was owned by someone who isnt into modding car (seem like it)OutToWinPAHC wrote:if it runs and drives for under 1200 it is. Is it swapped / modded?
I'm pretty sure you can put a 96 head on a 94, but not vise versa. 96 head has some extra sensors and crap IIRC for OBD II that the 94 doesn't need/use.Jay420sx wrote:Ok I have a question. About 2 hours ago a mechanic friend of mine took a look at my Ka dohc. Now he said by the looks of the valve cover color he thinks it looks like a 96' engine. And the guy I bought it off of said hes pretty sure it was a 94'. So how can I tell exactly what year engine I have? Would headers fit a 94' and a 96' dohc the same? I dont think they would so this is why Im curious...
If there are no fingers in the hole then nothing goes there. Its for anoption that you don't have..Scuffed_ChukiCoupe wrote:So my cluster does not work... There is an aftermarket radio there, it looks like it was improperly installed and it was stated the tsu box (whitebox next to fuse block at driver footwell) might have a blown fuse. So i swapped out that box with another, nothing still... and! I noticed at the fusebox by the footwell all the way bottom left fuse *ignition electronics* That fuse is missing and there are no metal strips inside the fusebox as if a fuse was ever there Does that even have anything to do with the cluster though?
