You did? I didn't get anything. Or did you mail it to [email protected] ?OdsGeorge wrote:emailed you the background of the situation...
That question is probably better suited as its own thread... definitely not a newbie question.ihollow wrote:got a question.. i failed inspection in NJ for a few things, minor problems. but something i do not know how to fix is how to get high beams. i have 8k HIDs on and i guess i'm technically riding with the high beams on, but i still failed. is there any way to mess with the HIDs to get a high beam or did i do something wrong in installation? OR is there no way i can get high beams.. i searched nico and couldn't find an answer so there are my questions
There is a link to factory service manuals in my sig. You'll find the wiring diagram there.sotamikess14 wrote:Well im new to the site and i have a 95 nissan 240sx and was wondering where i could find a wiring diagram for the stock Ka? i havent been able to fine it and u would think i would have this hard of a time finding it
Yeah, there was a tube there from the factory, but it isn't required.justinedible4 wrote:My dad noticed this question this past weekend while fiddling with the car but is there supposed to be a air duct/hose that runs between these two holes that I have circled in this image?Thank you for the help in advance.
Found it in my spam folder... odd. I wonder if anyone else is having problems accessing the classifieds.OdsGeorge wrote:emailed you back...
Yeah it basically says something like not allowed to participate in this part of the forum
ODB2 S14 5 speeds have a hole in the bell housing for a CAS.Dire91 wrote:Thanks for the help guys, another question though. The previous owner did a 5 speed swap and is there anyway to tell the difference between an S13 trans and an S14 one?
Where is the hole located on the bell housing, and what's a CAS?OutToWinPAHC wrote:
you can just eliminate the shroud all together.rootS13 wrote:okay.. I just swapped in a dohc into my 90 chassis. My fan brushes against the top of the shroud when the cars running. Is there a safe way to cut the shroud to avoid this or a way to raise it up higher? Or is there a different shroud to use?
it should fit. take a measuring tape and compare the 2 to be sure.JoseBronx wrote:so does anyone know if a auto sunroof from a s13 coupe would fit into a hatch?
poppycock. Who told you that? You should be able to look at it and determine if that will happen. Do you have pictures?rootS13 wrote:I was told that would be dangerous, since it might run into the intake.
have you ever stopped and thought about the kind of gas you were using or where you were getting it from...this used to happen to my 06 mustang, and my impala. i was getting gas at the same place, and it would always die...it was because there was water in the gas at the station. put some seafoam, or heat in it. and gas from a diff station.DriftTwin86 wrote:Well I'm back again. I'm here because my car is acting up. I replaced alot on my car because of this problem. Just a bit ago I was pullin into my apartment complex and my car just died. It says I have gas just a bit below a quarter tank, it cranks and cranks and cranks but it won't start up.
My 240 is a 93 KA24DE.
I had this same problem a few months back and it just went away after awhile. I can't afford or wait for this problem to stop again. If I let it sit all night it will start up in the morning, but I can't rely on that because I don't need ot have this thing die on me while I'm out drivin around, it dying when I come home has been pure luck.
It has a 95 Kouki fuel pump in it, I've drained the tank and cleaned it, replaced the fuel lines and the filter at the front, carb cleaned the pump filter, replaced the coil and the entire set up attached to the coil, plugs, o2 senor, dizzy cab and bug, plug wires, checked all my fuses, replaced fusible links and even replace igition relays, also checked ground wires.
Why would it let me drive it all day and then out of no where die and not start up?
