Nico has a write up about it for the dual cams. Here is said thread. Thank you come again.IKGamex wrote:Hey guys, I got one that's extremely dumb. Could someone take a picture of a ka24e and point out the location of the idle adjustment screw and TPS?
Sounds like you have corrosion on the injector connectors. Get some CRC quick dry contact cleaner and a wire bush, clean up the connections and see if it helps. As far as the cluster, I haven't messed with themice_man152 wrote:hey guys, i made a post on here but not really gettin much response on it. it was in the tech part of the forum, figured id ask on here. I just gottta wiring ?
Gotta 89 sohc put into a 91 but i think the 91 had a dohc, used sohc engine harness, but the harness in the 91 was already in so we just plugged into it. My question is that i have two gauge clusters from my 89 (long story...bought it off of a redneck who put CDM cluster thats in khm in it and kept the usdm one)
ANyways.. I plug the cluster in and my clock works, and the high beams light works n thats it. i put 20 bucks of gas in it the other day n after half hr of driving the gauge barely moved so i dunno if its gonna work either. But speedo, tach, oil n temp dont work at all. THe little two foot harness going from the cluster to the main harness that u can interchange, i have two of em and tried em both but neither did nething different. JUstt needing put in the right direction :-/ love my car to death but this is killing me.
Also another stupid problem is that i think my fuel injector clips have dry rotted wires lol i touch n injector and it runs on three cyls and sounds like a F-ing subaru... is that just the wires or could it be somethin related? ive done bout all i know to do. New with my 240 been working on dsm's for bout four years.
Sorry I left out I replaced my injectors and had my fuel rail cleaned also and new O rings. But I don't have a hard starting issue, I just have a loss of power after the first drive of the day and a light boggin down and sputterin issue when drivin off in 1st gear. Backfiring from the intake with no cat is normal? Or are you sayin back firing from the exhaust with no cat is normal, I'd assume from the exhaust is kinda normal, but mine back fires from the intake which I don't find normal, I can recreate this intake backfire easily and when my butterfly valves are opened manually it no longer does this. So would removing my emissions which contains the butterfly valves completely fix this problem, and do you think it'd give me back my power that I loss once the 240 has warmed up?OutToWinPAHC wrote:Injector(s). Backfiring with the no cat can be normal, but the hard start sounds like a leaky injector thats causing fuel pooling in the CC. Remove thr rail, clean it up, and try replacing the O rings first. If you do replace the injectors beware of the aftermarket ones.
You should most likely make sure every harness on the 240 is a single cam harness, if you are running a single cam. If you know each harness is a single then it could be a faulty cluster or just bad connecter or connection on the plug ins, you'll see on the back of the cluster a blue cover with copper in it, look over it all and look for any broken areas. My coupe had two completely broken through and i had to soder replacements in. Make sure your gauge cluster is a single cam cluster as well, you can tell this by the top speed being 115 and not 110. OR WORST CASE SCENARIO, you unwrap your entire wiring harness and check for broken wiresice_man152 wrote:hey guys, i made a post on here but not really gettin much response on it. it was in the tech part of the forum, figured id ask on here. I just gottta wiring ?
No idea, I bought the car 3 years ago and it was being parted out, so as i think about it now it most likely could have been cause why would anyone part out a perfectly good car if it ran unless they were having issues with it? Right?OutToWinPAHC wrote:Oh its an intake backfire. Sounds like you need to find TDC and re-time her, don drive it if it keeps backfiring thought the intake, its gonna damage things like intake temp sensor, IAC, and the MAF.
Were the cams pulled at all?
Have him double check his work just to make sure, uh I have no idea if the interior harness is different on a single or if its the same as a dual. I wanna say its different cause nissan made changes when they changed engines and with the 240s each year.ice_man152 wrote:see i had both clusters working in my 89 sohc and i took em out, set em on a shelf n then put em in the new car. yea i like dohc better too but i got a sohc for cheap n its good enough for now. ok basically i took everything outta my 89 and put into a rolling shell. motor, trans, engine harness and my friend is the one who plugged it in, he has a 240 also. but he said that the engine harness plugged into the harness inside the car. vin plate says my 91 is a dohc car so is the interior harness on a dohc diff than a sohc? REAAAALLY appreciate the help though guys
^^^lol thats funny. sometimes i spin 2 and sometimes i only spin 1.PyR0NiAk wrote:
Do a burnout. Then get out and check your black marks. If you have 2, you have an lsd. If you have one, you don't.
I've seen 5 spd trannies go for $200... so if it's a 5 spd.. it's def worth it for parts if nothing else... 165k+ it's looking at needing a rebuild though... You'll also need the computer and wiring harness to install it...JoseBronx wrote:another noob needing help,...
1st off big thanks too everyone taking time to answer question in this thread.
I have a single cam that is giving me trouble so instead of even dealing with that Im just going to get a twin cam and plan to swap it in my pignose. I found a twin cam for $200 with 165K + miles on it. Is there anything in particular that I should be looking for when I go check it out tomorrow?
The guy said that it has just been sitting there because the previous owner abandon it. Its in a garage so they said theyll take it out the car.
Me being a noob I think it sound too good to be true but Im not too sure.
My question is should I go take a look at it or not waste my time. 165K+ miles on it. Engine and transmission for $200
