I'm New Here And I have A Simple Question Thread, (No Flaming Allowed)
Pdawg
Car: Grand Prix GTP - 240sx envy
Yes.
Johnnie
Car: 1990 240sx Fastback
Which steering wheel hub would I need to replace the stock steering wheel on my 90 240 (with cruise control, that is now broken and I don't want to keep it) with a momo or sparco steering wheel, as the stock one has seen a lot of heat and the rubber is now too sticky and nasty to hold. who should I buy this from>thanks a lot
AZ89two4Tsx
Don't tell anyone I linked you to this.
PapaSmurf2k3
Site Admin
Pdawg wrote:Yes.
Yeah, you don't want to be slapping a $2000 turbo kit on your DD. You can do a lot more with the 240 though... RWD is definitely more fun, and the compression ratio isn't as high as the Honda's (so you can turbo it later on down the road).
wetwilly215
Car: '93 Nissan 240SX
Does anybody know any good/ reputable shops in Philly or Jersey that mess with 240's
PapaSmurf2k3
Site Admin
wetwilly215 wrote:Does anybody know any good/ reputable shops in Philly or Jersey that mess with 240's
your best bet would be to check the regional forums.
Bob Norman
Car: 1996 Nissan Silvia S14
I own a 96 S14 and am having problems with the horn, it appears that every time I accelerate slightly while turning left the horn sounds suddenly for a few seconds. I have disconnected it for the time being but was just wondering if anyone knew what i could do to fix it, as i need a working horn to pass its next wof, any help would be appreciated
PapaSmurf2k3
Site Admin
haha that sucks man, my brother used to have a problem like that, but it was in his POS hyundai.Anyway, we had to pull the front of the steering wheel off, where the contacts for the horn were... and one of them was shorting out on something.
Next time it happens, try banging on the column or near where the button for the horn is... if it skips a little bit, your shorting it out somewhere.
Pdawg
How much could i expect to pay for a 5 speed swap, parts and all, and how much would i get for the auto with 70k on it? Im looking at a nice zenk with only 70k for a good price, the only problem is its an auto.
PapaSmurf2k3
Site Admin
figure to pay a shop to convert it to 5 speed... maybe $1200-1500ish? That can go up if you buy go fast goodies like beefy clutches and rebuild the transmission and stuff... as for the used auto... I dunno, not much at all. Probably about however much its worth in scrap aluminum. ($75?)
Colin1337
Car: 1990 Sil80
so i have had absolutely NO luck getting a drivers seat for my s13.i have looked everywhere, and im always to late or the dude doesnt reply. even the local shop i tried has flaked on me and keeps forgetting to pick one up for me.
so the car i bought has the passenger seat, can i just swap the passenger side with the drivers side? any reasons why that wouldnt work? im getting kinda desperate, and dont want to drop $400 on a race seat, i just want to be able to drive my car.
djnicky240
Car: 1992 240sx fastback, 1992 240sx vert 5speed swapped,1991 240sx SuperHicas
I have a 92 240 auto nicely tuned for a few years and just picked up a 91 240 5speed SE Hicas. The 91 hauls a**. Does the SE have a factory upgrade to the engine?
PapaSmurf2k3
Site Admin
they are rated at the same peak power level, but maybe the curve in the 91 is a little better? 91's have more aggressive cams. The manual transmission makes a big difference too.
rb25det250sx
Car: '96 Nissan 240SX RB25DET powered!!!
try junk yards man. . . i can get like 8 up here in iowa for pry a total of 250. seats are cheap.
Johnnie
trying to register my 240 (ka24e) and i'm hitting some road blocks...any legal recommendations for a gross polluter, a little info...--terribly low idle, terribly high hydrocarbon, terrible gas mileage (about half of what it's rated at), occasionally dies at idle (stops signs, speed bumps, etc.), I just changed the coolant temperature sensor, and temperature gauge sender, and they helped a little bit, but not nearly enough. here's the smog test.
I don't want to trick the sniffer with denatured alcohol or temporary additives, i want to fix this.I have an idea that it might be either a lot of carbon build up and maybe seafoam can help that, or bad injectors?any help is appreciated.Thanks!
driver42484
Car: 91 s13 silvia 88 mr2 sc
So this forum is horrible. I hate the security you guys have on posting. I usually spend most of my time reading others posts and using the search icon to find what i need. but now i cant post in the classifieds... yes i read the rules.... but come on. Can you guys just get a spam blocker? or do like we do on driftpa.com and just delete them? maybe the numbers of this type of thing are too great for that. Which i can understand... of to do my 10 posts..... this is so lame
bman49
Car: 1990 Ford F250, 1998 Nissan 200sx
Ok this is probably a stupid question, but why is the 300zx brake swap so popular? Isn't it easier to buy a big brake package for the 240sx? Also on S14's, is the rear brake drum or disc?
PapaSmurf2k3
Site Admin
the Z32 brake upgrade is so popular because it is MUCH cheaper than a big brake kit... and uses factory Nissan equipment, which there are lots of different brands of pads and rotors for. It is also quite the easy swap... the calipers bolt right on to the factory spindles. All you have to do is change brake lines (along with the other hardware).
S14- Rear brakes are disc, but they have an internal drum for E-brake.
AZ89two4Tsx
Don't forget the master cylinder & booster!
bman49
thanks guys I also have another question. I've tried searching and there seem to be some people who have put a S15 HLSD into a S14 pumpkin, but is it as straight forward as they make it seem? Also what parts would you need?
Modified by bman49 at 8:37 AM 6/4/2009
panda dozer
i have a 1990 240 that im doin work on and im tryin to find wheels and tiers for but i cant find any strait 4 lug. all i find is those gay wheels with like 40 holes and other than that i only find stock. where can i find good wheels and tires.
AZ89two4Tsx
It's all about your budget. My wheels are 4lug.
bman, if you don't get any answers here, try the 240sx tech section.
milkdudz145
Hello all im new here and have a qeustion if its not too personal. After looking at the picture threads of awsome 240s, 180s etc i was wondering what everyone does for a living to pay for there mods and such. Im 17 and im planning on getting a job as soon as i can get an interview. Im looking to start saving and buy a used 240 or FC or maybe a FD not sure and also how old are some of you if thats not too personal.
Also were did some of you learn to do what you do to your cars.
PapaSmurf2k3
Site Admin
You're a little behind the 8 ball there Junior, you should have gotten a job when you were 14...
And you learn by coming to the forum! After you read some crap, you go out there, and do it yourself.
justinedible4
Car: 1990 Honda Accord, 1991 S13 HB
i have 2 questions.1. If I were to use my e-brake to initiate a drift a lot then would that abuse burn up my e-brak and cause it to eventually not work when i put it in park or not work at all?2. What is an itb on an engine and what does it do? I see all these guys use acronyms for stuff but I dont know what they are so if you could go over basic ones then that would be great.Thank you guys for such a great place to come and learn about a fascinating car.
rb25det250sx
panda dozer wrote:i have a 1990 240 that im doin work on and im tryin to find wheels and tiers for but i cant find any strait 4 lug. all i find is those gay wheels with like 40 holes and other than that i only find stock. where can i find good wheels and tires.
BUY MY RIMS!!!!
milkdudz145 wrote:Hello all im new here and have a qeustion if its not too personal. After looking at the picture threads of awsome 240s, 180s etc i was wondering what everyone does for a living to pay for there mods and such. Im 17 and im planning on getting a job as soon as i can get an interview. Im looking to start saving and buy a used 240 or FC or maybe a FD not sure and also how old are some of you if thats not too personal.
Hey buddie im 17 to and i work for a constrection company... so im make perty damn good money. just need to get work done to my car... THIS FORUM IS GREAT, because everyone will help you out with what you need and answer your questions based on what they know so it also helps expand what you know about your car.also you can find someone in your area that knows more than you! helps a lot!!!
justinedible4 wrote:i have 2 questions.1. If I were to use my e-brake to initiate a drift a lot then would that abuse burn up my e-brak and cause it to eventually not work when i put it in park or not work at all?2. What is an itb on an engine and what does it do? I see all these guys use acronyms for stuff but I dont know what they are so if you could go over basic ones then that would be great.Thank you guys for such a great place to come and learn about a fascinating car.
1. same as any brake, you will still have to replace the pads. BUT if you just use it to intiate the drift it should last a while since its not constantly dragging.2. your guess is as good as mine!
two40sON240s
ok so i guess there are some 240s with all wheel drive steering... thats probably not good for drifting can i take it off of the car
Johnnie
^^^anyone?
SpecD_240sx
Car: Nissan 240sx
Think you mean All Wheel Steering, most of the time known as HICAS. I wouldn't say it's the easiest thing to take out but it can be down. This should help you out.
http://www.n-e-c-c.com/beta/showthread.php?t=3606
odmoht
i am in need of some help.i just finished putting my j30 front calipers on and i put my rims on then i noticed that my rims and calipers were touching literally...i thought the j30 calipers could clear stock oem rims...i would assume they would clear my rims which are ssr reverse mesh 15x6.5 +8.do i need spacers? or did i put them in wrong o.0any help is appreciated!
