sorrowfulkiller wrote:I'm thinking of buying a 240sx project car, pig nose s13 hatch actually. It'll be february after I get back from basic and tech school and I want some info.
What are some things that the average person may not know about them?Do 240sx's have any major issues that I should be aware about?What should I look for in a good car for building up? (aside from bent frame of course)I also heard BC cams were absolute crap in the ka24de's is this true? and if so what are some other widely known and trusted cams?
First of all, the pignose didn't come with the KA24DE. The average 240 person should know that frame rot is common, as well as in the rocker panels, and strut towers. Other than that, S13 driver's side seat is messed up almost 100% of the time.When looking for a good car to build up, it depends on what you are trying to build it for... if you are keeping the stock engine, and not rebuilding it, you should look at your compression, gaskets, belts, hoses, and the condition of the radiator. That would give you a good base for a decent build on a 240... if you are going for big numbers, you are either going to be swapping out the KA, or rebuilding it, so a lot of the above stuff doesn't matter.
JWT cams are good 240 cams.
That is most of the 240 specific info when buying... when modifying, there is a whole slew of additional info you should know about.
