2ndnissan wrote:ok..never had a vlsd apart , so here's the question.I want to help someone out on the forum while maybe getting rid of my stock open diff. There is a 95 j-30 in the salvage yard. Owner wants $150 for the diff . It's a five point. The person on the forum needs five point output shafts. The question is....if I got this rear could I take out the five point outputs for him and use my stock outputs in the diff? basically...would the shafts from the open diff have the same diameters and splines? or do I have to have vlsd six point shafts?
IIRC you can definitely change out the halfshafts... how to do it though, I have no idea.
mastermindspr04 wrote:Haven't test the compression yet on the car plan on doing that tomorrow when I buy the tester. This is going to be my first compression test since this is my first project car. Any suggestions on what steps to take to get good results also had a question could a bad starter give bad results as well because I know I'm getting a loud crank from the start motor since the clutch was replaced Thanx.
No, a bad starter will not cause a bad 1/4 mile time unless your car is off while sitting at the tree, and you can't get it started before taking off.
