email phase 2 and ask them how much it would cost. I told you already how much to expect.kotul wrote:Where Would I get a wiring harness for a rb25det and how much would it cost?
[email protected]
They don't list it in their website, but I'm pretty sure they have harnesses in stock.
I'd check your mafs... that could be a possibility. I had the same exact problem... low idle and smoking at idle.theBird wrote:So I went ahead and bought this '91 240sx: zerothread?id=216489
I've searched for the past 2 days and I haven't seen anyone with an idle problem similar. I have some ideas what it could be...
The car runs excellent under boost and just regular cruisin'. It has plently of power and it starts up fine everytime. Problem is a low mis-firing idle. When the engine is warmed up, the idle will drop to 500-600rpm and it will start to misfire and blow either grey or black smoke out of the exhaust. Sometimes the RPMs drop so low but never stalls out. Somtimes this doesn't happen and it idles fine at like 900rpm. I monitor the voltage from o2 sensor via the turbo timer, but it is never extremely rich when this happens. Once I get moving it will be fine and no smoke at all. I'm not sure if the smoke is from oil or unburned fuel. I've put in new NKG bkr7e spark plugs, no help.
Any ideas as to what could be causing this low/smokey idle?
~Try this~ Warm up the car, drive it, then when its at idle and its starting to idle like sh1t and smoke, pop the hood, and unplug your mafs. If the idle corrects itself, then you know for sure that it's the mafs. ~this is just to check~
In that case, clean it with a mafs cleaner, or get a new mafs.
theres a guy at my local 240 meet that me and my friends host that runs 19's on his s14...bkmc wrote:are 19's too large for s14? i dont see anyone running them
looks like crap... 18's are the biggest I'd go... if you go 19's, might as well get some lambo doors and start subscribing to DUB mag instead of import mags, LOL
iirc, they will if you change the bellhousing...and next time be more specific, S14's do come with sr20's already (notchtops)gukdoebabdoe wrote:do all sr20 engines fit the s14 transmission?
