PapaSmurf2k3 »
https://forums.nicoclub.com/papasmurf2k3-u3044.html
Tue Dec 09, 2008 12:33 pm
First off, welcome to NICO!
We have a GREAT search feature on this site. ALL of your questions can be answered using it. As far as body kits go, that is pretty opinion based, and out of my field of expertise. Transmission swaps have been covered in detail, and again, a simple search should reveal a How To on that. If you want to keep the same motor and turbo it, visit NICO's KAT section. Some of the smartest guys in the forum are there, and can help you with whatever you need (along with the stickes at the top of the threads). Exhaust is whatever you can dream up. The sky is the limit with that one. It is a pretty easy mod, and fairly straightforward.For a radiator: if your stocker is in good shape, I'd keep it until you start having heating problems. I have a stock radiator in my KA-T 240sx and have no overheating problems. I have removed my mechanical fan, but keep the electric fan on all the time. If you want something flashy, you should check out Koyo racing alluminum radiators. I have one in my prelude and love it.Fog lamps usually come with directions when you buy them, but they are one of the simplest DIY electrical mods there is. 3 wires and a switch.
for a 5 lug conversion you will need 5 lug hubs (look for some from an S14 SE). They should bolt right in. Front 300zx brakes will bolt right on with new rotors (5 lug), but rears are a little more tricky. Rims and tires are again opinionated on size, but to avoid a sunken battleship type look, you should try to find something with an offset lower than +30. Coilovers will vary on what type of setup you want to run, how hard you want them, etc. Many NICO sponsors sell them, and can help you choose the right set.
Again, welcome to NICO Sean!
