hazukijitsu wrote:PapaSmurf!!! two questions.
First, My speedometer stopped working, then the next day it works on and off. I noticed that the mileage isnt moving either, so my cluster isnt showing how fast im going or counting my mileage, everything else is fine. I pulled out the speed sensor, hooked it to a voltage regulator, turned the little gear and its showing a signal. Any Ideas?
Also My 240sx seems to overheat when I exit the freeway and stop. I drive on the streets stop and go with no problem. It happened about 2 times. I drive on the freeway going about 70 mph for about an hour, I exit the freeway and wait at a light for about a min or so and my car overheats. But once I start driving with no stops, the car temp go back to normal
Thanks Papa Smurf
I'm not Smurf but I'll give it a try.
1. I seem to be having the same problem. I too checked my speed sensor and turned it and sure enough, the speedo needle moved fine. The conclusion me and my dad came to is it's not the speed sensor, it's the gear in the transmission that turns the speed sensor. Yeah, sucks if that's what it is.
2. Well since there is much more airflow when you are driving that could be what is keeping your engine from overheating. Either way, sounds like you have a cooling issue. Make sure you don't have any disconnected hoses or any leaks and go from there.
I'm sure Smurf will be here tomorrow to give more assistance. G'day to ya.
