6-pac wrote:I recently purchased my 92 240sx SE hatch and the power steering began to leak almost immediately, then I realized it was at the boot on the rack. The pump quit a day later with fluid. I don't have a problem steering this thing whatsoever without it. However, once I noticed that it had quit, it began to overheat slightly climbing to approx 80%. Can this have anything to do with the pump pulling too hard on the fan/waterpump? (sorry...noob)
The guy I bought it from said that it had a new water pump installed, and to try putting a new radiator cap on it. The last time I did that (old car), it created so much pressure it tried to blow up my car! hahah, I had to put the old one back on and it ran fine. I'm gonna replace the thermostat tomorrow and see if that helps at all. Hopefully get the rack and the pump in a couple of weeks... (broke dude).
Any suggestions or help are much appreciated. Thanks ahead of time. By the way, the engine is very solid.
If you are running the pump with no fluid, it is probably screaming it's little heart out. I suggest you fix the power steering first, then swap in a new thermostat and change your coolant. Check your water pump while the car is running, and see if it has any shaft play or little leaks or anything.
