My friend and I jacked up both side and let the wheels spin and there was no noise. Were going to replace the brake pads and use brake lube and see if that fixes anything. They need to be changed even though they have a decent amount left. The fan I dunno, its still sounds very loud, like a jet, especially around 50 plus MPH. Hopefully it will fix itself ! Anything else?PapaSmurf2k3 wrote:Hmmm... The reverse grinding problem should be somewhat easy to check out. Jack your car up and spin the rear wheels backwards. I'm guessing it still makes the noise if you are going backwards in neutral?
The noise from the front is going to be a little more difficult. You are going to have to pop your hood and check out your belts and see if anything is out of the ordinary. If it looks all right, start the car up and try to listen closely to pinpoint where it is coming from. If you see anything out of the ordinary, try and snap a picture for us.
We'll get you pointed in the right direction.
I assume you are talking to me. So, I don't know how many times I've told you, but I know nothing about any of that JDM type stuff. Limited SR knowledge, 0 about any conversions. So, either wait for someone else to post up (doubtful), or put your thread in the 240 gen section, or SR section.Scuffed_ChukiCoupe wrote:what happens a brotha dsnt post 4 a while and he's not important ne more...
Well, you COULD jack up the rear and start the car and throw it in reverse, and go slowly and have someone listen for you. Sorry I can't really help, but I'm not there, and you have to use your senses so that you can pinpoint where it is. The only thing else I can suggest is to take some video and post it to us.hazukijitsu wrote:
You sound like you have a pretty good idea of what you are doing and what you need to do. I'm pretty sure that 225's will fit on a 7.5" rim, but you miiight have to go up to an 8. Your best bet would be to check the wheel and tire forum, or to call tire rack and check with them. Make a thread about it when you guys get rolling, the NICO members here would LOVE to see it. Document the race as much as possible too.JClark wrote:Hey guys, great idea for a thread.
My friends and I just picked up an 89 240 to race in the 24hrs of Lemons. It's a 24 hour race for beaters basically. http://www.24hoursoflemons.com/
Wheels and tires are considered safety items and therefore arent budget restricted, however we'd like to save money.
What can we fit on the car using the same wheel/tire on both the front and rear? What are the specs (width and offset)? We want to stick with a non-staggered setup to make pitstop tire changes quick and easy.
We were hoping to use 16x7.5 wheels all around with a 225 wide tire. Is this possible? TireRack makes it look like it is. Is there a better idea?
Spacers are fine if necessary.
Thanks for the help.
-Jesse
hazukijitsu wrote:My friend aCongrats man! Doesn't it feel good to fix stuff yourself?PapaSmurf2k3 wrote:
Well, you COULD jack up the rear and start the car and throw it in reverse, and go slowly and have someone listen for you. Sorry I can't really help, but I'm not there, and you have to use your senses so that you can pinpoint where it is. The only thing else I can suggest is to take some video and post it to us.[/QUOTE
My friend and I put new brake pads with some lubricant today..........and the noise is GONE! The thing was that the brake pads were still decent, and were about to touch the indicators, so I havent heard the reverse noise ever since!
Now for the noise in the front, today I tried spinning the fan by hand, and it is giving me resistance, its not spinning freely. The fan is still loud when I drive, like a jet or something. You think it might by the Fan Clutch and/or water pump?
Thanks again papasmurf for taking time to answer my questions
As for the front- you could TRY unbolting the fan from the water pump flange there, and see if the noise goes away. If not, it may be the water pump. There are 4 10mm bolts holding that assembly on. You'll probably have to remove the fan shroud as well. I did all that, and never put it back on.
Thanks P-smurph. I'll post up a thread when we start tearing it apart.PapaSmurf2k3 wrote:
Sounds like you need to resolder those wires (or better yet, completely replace that sensor). Also check your engine grounds. I had a similar problem when mine were shot.onemad240 wrote:ok i am still trying to get more pics up but until then i have some mo info. those pics are of wires that lead to the intake air temperature sensor and the intake air temperature sensor leads to the maf sensor. earlier i went to put electrical tape around them and the wires broke completely off from the metal piece. i drove around a little bit and the engine performed no different. what da fudge is up?
Modified by onemad240 at 1:24 PM 10/27/2008
