zenki95 wrote:what do i need to remove from the engine bay in order to take out the EGR tube and install a block off plate?
In addition to what warped said, be advised that the EGR tube is a royal pain in the *** to get out from the exhaust manifold. You might have to heat it up and get like, an 8 foot cheater bar to loosen it. You'll probably want to remove your heat shield altogether during the process. You will then remove the EGR tube, and plug the hole you will have in your exhaust, and then buy or make an EGR blockoff plate and install that when you remove the actual EGR valve. It is a pretty straight forward removal (besides being in a tight spot).
zenki95 wrote:i just checked my ecu for the CELs ive been runnin since i got my car.they are:
33 - Front O2 Sensor37 - Closed Loop105 - EGRC Solenoid/V
for 33, im sure i probably need to buy a spacer/extender for my o2 sensor right? (b/c of aftermarket headers)? but for the other two codes im throwing, i have no clue what to do..does anybody know what i need to do in order to eliminate these codes?
Well, I don't see why you would need a spacer for your O2 sensor, would you care to elaborate? Are your aftermarket headers so crappy that they do something freaky to the O2 sensor? The other 2 codes, you might have to search in 240 FAQ for what exactly they mean. You should first try seafoaming the car and then resetting the ECU to see if the EGR fault goes away, and maybe the closed loop fault as well. You will DEFINITELY have to replace your O2 sensor after a seafoaming.
