I'm New Here And I have A Simple Question Thread, (No Flaming Allowed)
rzerob
Car: 1997 240sx LE
Does anyone know what the stock gear raito is in the s14? Papasmurf I am mainly looking to you because you seem to know everything and are my go to guy.
THanks,
Rzerob
PapaSmurf2k3
Site Admin
The 240 comes with a 4.08 rear end gear ratio.
PapaSmurf2k3
Site Admin
popi-dude wrote:
my goal is to get about 200-250 hp to the crank.. so i could only buy a t3 and drop the whole thing into the enginebay ?
so if i understood, the weak point of the KA is the pistons ??how much does it cost to change them 2-300 bucks ?
would a 250 hp set up with new pistons would be fine ? or i'd have to change valves and some other internals ???
200-250 at the crank is easily attainable. Buy the T3, a manifold, downpipe, Rising Rate Fuel Pressure Regulator, Walbro fuel pump (255 liters per hour). You could probably get to that power level without even using an intercooler, but it is a good investment (along with a blow off valve).
You can make your power goals without breaking into the motor at all. Perform the mods I was telling you about, run about 7 PSI, turn the timing back roughly 1 degree and run an 8:1 RRFPR. That ought to do it for you, but beware of the boost bug. You will want to turn the boost up, but PLEASE refrain until you upgrade your fuel system.
Forged pistons will run you roughly $400, and changing them out varies. You could do it yourself, but figure paying someone to do it might cost you an additional $400 ish? Honestly I don't know, I've never had anyone just change the pistons.
megaderk wrote:whats the difference between the KA and CA engines?
and what was the HP for the stocl KA24E?
Well, there are many difference between the 2 motors, Bore, Stroke, and with that, displacement. The CA is a 1.8 liter, and the KA series is a 2.4 liter. The KA24E produces around 145 HP, and the KA24DE produces 155HP.
jakums wrote:ok so i posted something on turboing my ka24e motor. looking to make 300-350 hp im also thinking on doing forged internals is this a good set up
cp 8.0 pistons 500$turbonetics t3/t4 50 turbo 745$universal turbo piping includes intercooler and blow off valve 250$APEXi SAFC-II piggyback 400$wideband plx m300 350$jdm ka24de turbo manifold 150$greddy B spec 2 boost controller 120$tial 38.mm wastegate 305$
is that any good? Is there any was i could save a lil more money?
Modified by jakums at 2:42 PM 9/22/2008
You can go with slightly higher compression pistons. 8:1 is pretty low. I would go with 9:1 as long as premium is readily available for you. Good choice on the turbo. You don't have to get a wideband if you don't want. You could save some cash if you get rid of the wideband and the SAFC in favor of a tuned ECU. E-mance ECUs is operated by a member on this forum and has very good prices on tuned ECUs. You said you have a KA24E, but you listed a KA24DE manifold. That will not work, so you will have to find something else (and $150 is very cheap for a manifold, unless it is used).Don't forget to upgrade your fuel system. You will need a Walbro fuel pump and probably around 550cc injectors. Also, at those power levels you have just broken into the zone where you will need a 300zx (N62) MAF. You will also need an oil line feed and return kit.
1rst240sx
Car: 1989 Nissan 240SX
Hi Im new here and my question is , Will a 93 240sx Bumper bolt directly to a 1989 240sx and can I bring the blinkers over with it. Thank you
PapaSmurf2k3
Site Admin
IIRC, you have to also change the lower sections of the front fenders (that section that goes in front of the front wheels). Maybe try doing a search for chuki bumper swap? Maybe there is a HOW-TO writeup done on it.
zenki95
Car: 1995 240sx SE
i have a 95 240sx SE. i have stance gr coilovers and the car is dropped about an inch or so on the factory se rims. im looking at new rims and wanna kno which of the two combinations would fit better with my drop.
17x7 with 215/45R17or18x7.5 with 225/40R18
im looking for rims that will fit the car and drop well, but also wont reduce the performance too much. i was leaning more toward 17s but im a little uncertain if 17x7 with 215/45R17 with have too much of a gap in the wheel wells. with 18s, im scared they will be too big and i will start having to mess with the camber. help please? and pics if possible for assurance?
PapaSmurf2k3
Site Admin
Well, you should also be looking at what offsets the rims come in. They will determine whether or not your wheels sit flush with your fenders. I have 18s on my S13 with 235 tires and I don't have any rubbing issues at all. My tires are pretty old and worn though haha.
All your questions would probably get answered better in the Wheels & Tires forum. zeroforum/140Linked for your convenience
jakums
Car: 1990 240sx SE
so am i looking for a ecu chip or a complete ecu from e-mance??
any suggestions for pistons?
Modified by jakums at 1:39 PM 9/23/2008
PapaSmurf2k3
Site Admin
I would go for a complete ECU. As for pistons, I would go for some 9:1 forged pistons. The brand doesn't REALLY matter, just go with whatever is available. You might want to search through the classifieds too. Sometimes people buy this stuff and don't get around to using it, and you can basically find brand new stuff for less than they cost new.
popi-dude
Car: Nissan 240sx 1992
Wow, thanks papasmurf
so to my last question is about the management if i only boost 7psi with a t3 or t3/t4
what kind of management will i need ?a stand alone like a megasquirt or only a piggyback or something like that should be fine ? Thanks a lot for your help dude !
PapaSmurf2k3
Site Admin
Well, if money is tight, and you want to keep it as simple as possible, and are going to keep it at or under about 220 hp, you should be all right with an FMU (rising rate fuel pressure regulator)and walbro fuel pump.
You should probably go with a piggyback so you can upgrade in the future if you want to crank up the boost a little bit, which you will definitely want to do. That or go balls out right from the get go and get a tuned ECU. If that were the case, go with T3/T4 hybrid. If you just want 7 psi and are on a budget and are planning on going with the FMU, go with the T3.
popi-dude
Is the piggyback much more expansive than an FMU ? i heard that FMU's werent good management... so i dont wanna save pennys on the management tho... i dont want the KA to fall appart LOL
So here is my buylist for next summer :
t3 turbomanifold downpipeBovFmic with all the pippingpiggy back
anything else missing ?? oh yea an helmet
jakums
Car: 1990 240sx SE
alright thanks for the advise i owe you one
now just to get my dad to stop complaining about how im spending my money on dumb things lol
PapaSmurf2k3
Site Admin
popi-dude wrote:Is the piggyback much more expansive than an FMU ? i heard that FMU's werent good management... so i dont wanna save pennys on the management tho... i dont want the KA to fall appart LOL
No, an FMU is definitely not as good as a piggyback, but if you are only going for ~220hp or under, they are adequate. In addition to your list, you are going to need a fuel pump and new injectors to warrant the purchase of the piggyback. You will also need a new filter and method to mount it, including couplers and other stuff.
240pr06
Car: 1992 nissan 240sx
hey guysmy question is how many inches is a stock s13 exhaust, thinking of putting a new muffler on but i dont know if its a 2 or 2 1/5 inch inlet or what would work i was looking at something like thishttp://www.aspecproducts.com/images.asp?theid=6924and would this be loud on my stock ka24de? any suggestions and help are appreciated.thanks
PapaSmurf2k3
Site Admin
stock 240 exhaust is 2.25"
I've never heard of that muffler, but it looks decent. It also says it will be quiet, so your guess is as good as ours. You could probably get that one with the 2.5" inlet, but you will have to bring it to a muffler shop to get a reducer installed, but you will also need hangers installed on that muffler so you will be going there anyway (unless you have a welder).
240pr06
awesome thanks for the help, i do have a welder and torch to cut the old one and weld this one, and put the hangers but im not quite sure what you mean about the reducer?thanks again
PapaSmurf2k3
Site Admin
Well, the link you sent me had a 2.5" inlet. You'd have to make a reducer so you can adapt it down to 2.25". If you have a welder and all that fun stuff, you could just take the muffler to a muffler shop and get them to make you a reducer. Actually, I think they sell reducers and stuff at Autozone. Or you could just buy a 2.25" inlet muffler.
You should be able to figure it out once you get everything in front of you. Exhaust clamps should be able to clamp the muffler to the pipe/reducer just fine, but you will need the welder for the hangers. Make sure that the muffler is made out of a metal that you have the ability to weld.
240pr06
ohhh ok thanks for clearing that up, thanks for the help appreciate it.
jakums
Car: 1990 240sx SE
Ok so ive been asking lots of questions on turboing my s13i donno if i mentioned but its a the single ka24e but im hearing alot of talk about how there a waste to build and i should do atleast a ka24de swap but here is a video of a ka24et with about the same set up i want and its seems pretty beastly to me
http://www.youtube.com/watch?v=6kMNb8ShgFQ
I just want to kno if its a waste doesn't look like it but could be wrong
PapaSmurf2k3
Site Admin
No, it is definately NOT a waste. If you can find everything you need, you'll be fine. The reason a lot of people convert to the DE is because of better aftermarket support. The SOHC can put down really good numbers.
jakums
Car: 1990 240sx SE
haha good cuz i there some kid with a 220 hp eclipse that i want to show up so as soon as im done with that motor were ganna race and the car in that vid was pretty sick soo
thanks for clearing that up for me though
UK200SX
Car: 1998 200sx SR20DET
I'm new here. UKDM 200sx turbo, and I am looking for some new wheels and suspension upgrades. I looked in the Tire/Wheel/Brake/Suspension forum thread 'Where to buy' but many of the links are dead. Can someone recommend me a reputable website or 6 that sells wheels and suspension upgrades?
rzerob
Car: 1997 240sx LE
Hey Papasmurf I just read you wrote 4.08 gear ratio. I don't mean to doubt you because I am still new to nissan but I thought it was like 3.08. If it was 4.08 wouldn't I be running like 3500rpm at 55mph with my stock wheels? I only ask because I am considering changing the gear ratio but if it is actually 4.08 then I won't change it, but it doesn't seem like it is 4.08.
pejsa s-13
Car: 91 HardBody, 85 720
how do i make those lil computerized pics of my car to put in my sig?
Warped161
Car: 90 s13 the never ending project
Photoshop or corel pro.
PapaSmurf2k3
Site Admin
rzerob wrote:Hey Papasmurf I just read you wrote 4.08 gear ratio. I don't mean to doubt you because I am still new to nissan but I thought it was like 3.08. If it was 4.08 wouldn't I be running like 3500rpm at 55mph with my stock wheels? I only ask because I am considering changing the gear ratio but if it is actually 4.08 then I won't change it, but it doesn't seem like it is 4.08.
The rear end has a ratio of 4.08:1. That means that for every 1 spin of the driveshaft, the axles spin roughly 4 times. The transmission has different gear ratios for every gear, 4th gear is about 1:1 and 5th is .758 (I think).
UK200SX wrote:I'm new here. UKDM 200sx turbo, and I am looking for some new wheels and suspension upgrades. I looked in the Tire/Wheel/Brake/Suspension forum thread 'Where to buy' but many of the links are dead. Can someone recommend me a reputable website or 6 that sells wheels and suspension upgrades?
I'm working on this one too...
EDIT: should be fixed now. Try to buy from our sponsors first. Some of our sponsors specialize in pretty much everything you can imagine for the S-chassis. Enjuku racing is one of them, and have been a NICO sponsor for a long, long time. Phase2motortrend is also a great sponsor.
240pr06
my question is where is the bolt on the bottom of the radiator to drain the coolant?? have looked quickly but didnt see it, or how do i go about draining the coolant out?
megaderk
Car: '90 240sx coupe
is it illegal to run a daily driver without a catalytic converter on the car and to just replace it with a straight pipe?
i want to but my dad wont let me cuz he says its illegal an i will get a ticket.
Warped161
240pr06 wrote:my question is where is the bolt on the bottom of the radiator to drain the coolant?? have looked quickly but didnt see it, or how do i go about draining the coolant out?
Should be bottom driver side corner, a plastic screw.
megaderk wrote:is it illegal to run a daily driver without a catalytic converter on the car and to just replace it with a straight pipe?
Yes it is illegal in most states, your cat is what turns harmful carbon monoxide into carbon dioxide and water.
