A differential transfers mechanical energy from the driveshaft to the rear wheels. It is also known as a "pumpkin" and is found centralized in the rear of the car.There are many kinds of differentials, but the most common (from a factory) are: Open, Limited Slip (through some form whether it be viscous, clutch, helical, etc), and posi-locked.Welded diffs are basically welded to become posi locked. They make sure that both wheels spin at the same rate NO MATTER WHAT. This means that your turning goes to absolute crap, but you can kick the *** end out like nobody's business. They are also cheap. For these reasons, they are popular in the drift crowd, but should really only be used for drift only cars.megaderk wrote:whats the differential do?what kind are there?whats the difference between them?and i hear alot about welded diffs. what do they do?
Nissan's version of all wheel steering.megaderk wrote:whats Super Hicas?
1: If you are building a 600hp 4 banger, you are going to have to spend some money. Yes it is ok to use a used crank, but you absolutely must get it checked out 100% by a machine shop before you do. If they say it is ok, then it is OK.Speckid14 wrote:Is it ok to use a "used" crank on a KA24DE-(Soon to be T) that will be making over 600hp? What should be done to maintain safe operation, but not burn a hole in my pocket. I don't really want to spend the extra money to do more than knife-edge. Of course all bearings will be checked and all that good stuff. Thanks for your help!
Also if I get an Underdriven pulley like the Orthodox, ASP, or ATI, does that affect reading timing at all, or does the company make changes to compensate for the smaller pulley? I know if effects belt size, wouldn't that effect when engine accesories engage and disengage?Thanks again, its really appreciated!
Speckid
1) Yes, some 240SX's had Super Hicas. It was a relatively uncommon option, though.megaderk wrote:so the 240 has super hicas?
and whats the limited-slip do compared to an open?
High Capacity Actively Controlled Suspension, the super part means it is run by an electric motor instead of the steering pump. It includes speed sensors and a seperate control computer to determine direction and degree of turn. My understanding is that super hicas is actually bad for drifting, because the rear wheels would be turning to help you corner better instead of losing traction for the drift. most drifters disengage the hicas system for drifting.gshdrift879 wrote:For anyone who might know, this may be a dumb question but what does the Nissan super hicas exactly entail. I am not at all familiar with any type of four wheel steering other than the fact that it exists..but having never driven one i always wondered what differing handling characteristics would be b/t a super hicas 240 and say a standard rwd. Would one drift better than the other?
my SOHC cost me 1200 DOHC shouldn't be much morepopi-dude wrote:Here's a quick question how much does a ka24de engine rebuild cost ???
248 brand new from nissan, check local junk yards or post here in the parts needed section.http://www.courtesyparts.com/b....htmljbquick wrote:Just bought myslef a 90' 240sx and i would like to know if anyone can tell me how much a head light motor is gonna cost me?
cool, i tho it was more expansive, Is this rebuild making the engine like almost brand new ? well does it makes the ka24de ready for turbo ?Warped161 wrote:my SOHC cost me 1200 DOHC shouldn't be much more
Thouster you can go here and buy the bushing or get a brass one from cusco for 40 bucks. the stock one is a few bucks.http://www.courtesyparts.com/b....html
Mine had all new internals, oil pump, valve assembly, timing chain and honed walls.popi-dude wrote:
how many psi were you pushing in it with those internals ?Warped161 wrote:Mine had all new internals, oil pump, valve assembly, timing chain and honed walls.
thanks for helping out the new members, apreciate it I'll try to find more info by myselfWarped161 wrote:There is alot of info on here about boosting the ka's, you can either peice together a kit or buy one complete. As to the amount of boost, well thats under debate but you can push a decent amount. I'm aiming for a low of 6 and a high of about 12.zerothread/226410 start here.
my goal is to get about 200-250 hp to the crank.. so i could only buy a t3 and drop the whole thing into the enginebay ?PapaSmurf2k3 wrote:If you are going to be rebuilding your KA for boost purposes, you should upgrade at least the pistons while you are in there. Stock pistons are the weak link for KA internals when it comes to boost. This of course depends on your power goals. Anything past about 270 or 300 whp and you are DEFINATELY going to want pistons for reliability purposes. Some stock KA's have held up to 400ish WHP, but they are lucky and have done some great tuning. Forged pistons give you a little wiggle room.
Past about 400 whp you should think about getting forged connecting rods as well.
My DOHC rebuild cost me about $1400.
The ka24de makes 155 Hp stock.http://en.wikipedia.org/wiki/Nissan_CA_engine CA infomegaderk wrote:whats the difference between the KA and CA engines?
and what was the HP for the stocl KA24E?
