lashus wrote:Will the q45 brakes fit on 15" rim
If it is the SE rim, yes. Otherwise, I don't know.
the_grey_john wrote:I've searched but found alot of nothing.I am looking to upgrade my brake system all around.I see alot of kits for the front brakes, thats all good, but I have only found Rotora that makes brake kits for the rear.Does it really matter between front and rear kits or is all the same?I would like to put some billet aluminum calipers so I can anodize them to my liking.Can someone kindly explain to me whats up?
I just got 300zx brakes up front and have NEVER had a problem with them overheating. They are cheap and easy. That is what I would go with.
BMFer wrote:Hey guys, New here and i got a couple questions. Im in tha market to buy a 240sx hopefully before tha end of this summer. I was wondering, what are things i should look for and what are the best years?
BTW** my budget is under 3 grand.
Thanks
I'll make this easy for you. Look for 91 and up, and check your rocker panels and under any spoilers for rust. Generally look for rust all around. Thats all the advice I really have besides the normal listening for odd sounds etc.
the_grey_john wrote:Question One:I know you can buy a Honda S2000 button starter from a myriad of places, but I am not too keen on electronics, so would anyone see this as being a hard thing to set up with a little explanation? I am thinking if I can do a few wiring "practices" with simple stuff, I can open up to larger things, eventually to be able to efficiently wire up a engine swap. But I gotta start with small stuff. A push button start would cool and different. So, anyone with any ideas on that?
Question Two:Again, I have seen battery re-locaters, mostly from Odyssey and Optima (their batteries are cooool looking...).The Optima battery claims to be leak proof, so would there be a health hazard in me setting it up in the trunk area of my hatchback? Take note that I will also have some shallow set 12's in the back also and no backseat. Should I do it or not? I am trying to clear as much room up in my engine bay for my soon to have RB25/ NEO RB25.
You don't need a specific S2000 push button starter. In fact, I'm not even sure if that will work (is it a mechanical switch, like you hold it down and it cranks, or do you just push it once and the ECU takes over?). You'd be better off with a normal push button mechanical switch (one that doesn't lock obviously. You don't want to push the button and have it stick and keep cranking the starter even after the car has started).
2. I have a normal battery in my trunk (not optima). So no, there isn't really any danger. Get a nice battery box (I got mine from Autozone... I think it was a marine box), and then wire that bish up. Use thick *** wire for the grounds (I used 2 ga.) and thick wire for the positive going up front (I used 4 ga.). If you get into any trouble, a car audio specialist should be able to help you.
240lookis wrote:so, i have a noob question. i have a 2.5 inch piping catback exhaust. if i were to buy a test pipe with a 3" inlet and outlet would it fit my exhaust and stock headers? im asking this because i need something to replace my cat for the mean time because its shot. plus all the egay test pipes have 3" outlets, and i dont want to spend $100 on a test pipe when i will be replacing it soon.
It probably wouldn't fit. You could just make your own test pipe, I mean jeeze, its a straight pipe and 2 flanges. If you don't have a welder or the sack to do it yourself, I'm sure you could just go to an exhaust/muffler shop and they could do it for under $100.
Mangudai wrote:
Woah woah wait a sec. Everyone has told me NOT to use PS Fluid and to use ATF for the Power steering pump.
I don't know why they tell you that. I've been running normal PS fluid for years. Check your manual or something. They are both hydraulic fluids so there probably isn't too much of a difference.
