The little piece on the bottom of the fender doesn't match up IIRC. If you ca salvage that little piece from what you have, and incorporate the pignose fender, you should be all right.giodachamp wrote:would the chuki bumper bolt right in a pignose fender??....because i'm trying to buy a pignose fender for my chuki.
NA potential for the KA is not very high. To get it to run a 13 with the KA NA, you would have to really REALLY gut it, and probably do some serious NA modifications. Not worth it. If you are really serious about not going turbo and want an NA 240, look into ls1 swaps.BarMan wrote:i just join the forum and i yes i have a question ....
so here it is
i was wondering what is the potential N/a of the 240sx ka24de because i'm looking to sell my car and buying a 240sx
and was wondering if it could do 13sec on the ¼ mile N/A i would prefer without nos but if it need a bit of nos would be ok.... on a streetable Daily driver Set-up.....
thx for your help
Look out for rust. Also, if you plan on swapping the motor and trans, you can save a substantial ammount of money by buying just a shell.Simanovich wrote:hey i am new and thinking of starting a project car from like a '92 or '93 240sx and hints or advice
I think it depends on the design (which probably differs from company to company). You should ask Greg if his BRM exhaust does. Or better yet it has probably already been answered in the "Nex Exhaust for the S13/S14" thread in the 240 gen forum.shanelach wrote:Hey, I am looking to buy a new catback exhaust but was wondering, will a 3" exhaust bolt up to the stock cat? Would I just use the 3" gasket? Thanks in advance!
That really depends on personal preference. I know some professional drifters actually like sticky tires, while others like hard compound cheap *** crappy ones. My guess is that your car is not a professional drift car with 400hp, so you would probably be best off with cheap crappy non sticky tires.hjpan wrote:For the tires, what type is the best to drift with?
I am asking so I can prepare myself
oki thx but how fast could a 240sx go then would with all bolt-on possible and some camsPapaSmurf2k3 wrote:Sorry guys, I've been out. I just moved from RI to MS and don't have readily available internet.
They would probably have to be pretty thick spacers... I'm thinking like 20mm and over. but Yes, that is pretty easy.Scuffed_ChukiCoupe wrote:It could be agreed upon that a good machinist could fab up some 4 x 114.3 to 5 x 120 spacers... correct?
You miiiight be able to get into mid 14's. The cost to speed ratio is not worth it.BarMan wrote:
i look on dragtimes.com and saw some 240Sx do low 15 with only intake and timing adavance and do 90mph over 90mph in a car on that weight can do 14sec with a decent 60ft time
If you are swapping it into a car that previously had manual, you can bolt that bish right up.KiMbRoZz wrote:a buddy of mine is selling his 98 ka motor but the only thing is that it is auto transmission. I had plans on building a ka motor but blurring on if the auto transmission makes the motor different from a manual transmission. Can I just remove the transmission and slap a manual one on there or will parts like linkage, housing, crossmembers, etc. change?
Because it has to have room for the spacer to bolt onto the old hub, while not having the bolts or studs stick out the other side.Scuffed_ChukiCoupe wrote:why would they have to be so wide 4? That would be a very wide 240 lol, cause the rears are 255 wide.
Someone.....anyone, before I cry.Joesph R Cooper wrote:Ok, so today I found out that my car has Hicas......and that I cannot drift with it. HOW THE **** DO I FIX THIS? I've worked so hard for this car & put so much $ into it, when I bought it I was noobier than noob & had no idea what Hicas was....
I heard I can cut the lines & buy locking plates, but is this reliable to drift with?
I'm bummed......
What kind of noise? Is it a whining noise? If that is the case then yes, add fluid. Although it usually makes the noise weather you are turning or not. Also, does the noise get higher with RPMs? And the type of fluid to add is normal power steering fluid, not ATF, and not power steering fluid for Hondas.Kckouki wrote:Im not a newbie but have a question.
When I turn, the PS makes a noise, do I need to add fluid to it ?ATF fluid ?
Woah woah wait a sec. Everyone has told me NOT to use PS Fluid and to use ATF for the Power steering pump.PapaSmurf2k3 wrote:
