I'm New Here And I have A Simple Question Thread, (No Flaming Allowed)
PapaSmurf2k3
Site Admin
tosho014 wrote:Whats up guys new to the forum and recentely got my S14. My question is what would be the best wheels to buy for around $250 per wheel?I was looking at some of the 5zigen FN01R-C which look pretty good other then that i havent found much except cheap Sportmax and Rota (althougt i like the D2's). Thanks for the help!!!!!!
FN01R-C's are the wheel of 'yore. They were one of the first wheels available in 4 lug, and with good offsetts, so just about everyone bought them. For the best answer to your question, you should try visiting the wheels/suspension section of this forum.
Scuffed_ChukiCoupe wrote:LSD stands for limited slip differential. It basically allows both tires to spin at once. ITs better for racing applications because obviously tou want as much traction as possible to the ground. There are differnt types of lsd's though, theres the vlsd and hlsd and others i think (clutch type). Hlsd iuno how that works im sure somone will elaborate more, but vlsd stands for viscious and hlsd stands for helical. The vlsd is the crappier of the two, because it works like an open diff where on wheel spins all the time, but in a vlsd the fluid in the diff gets hot as one wheel spins and expands and locks the other side so it spins too. The helical i think has to do with gears though.
Essentially, the difference between the LSD's is how fast they react to the slipping wheel. For most purposes, a cheap VLSD unit will perform just fine.
kurbekis
Car: 90 nissan 240sx coupe
hey nico peoples, i just signed on this sight and am new here, i dont have any questions yet, just wanted to introduce myself, i have a 90 240 cpe, and am not new to the tuner scene, looking forward to talking to everyone,
Scuffed_ChukiCoupe
Car: Ka-t coupe
welcome, make a thread with some pics so more ppl get to know you, and stick around
Asmar
Car: 1994 Nissan Skyline
Very nice. Welcome to NICO. Looking forward to see pictures of your 240.
icu12sk4line
hi, my friend just got a 91 240sx hatch and just trying to research for her cuz she has no time cuz of school and all. well, her car came with no stock radio just the wires w/o the clip. so I need to know what each of the colored wires are (ground, power, etc)? because we wanna try and put an aftermarket deck in ourselves just to get familiarized with the car.
AZ89two4Tsx
The 89 hatch doesn't come with a factory lsd does it? Do any of the 240s? Just wondering.
89nissanS13
Car: 1989 Nissan 249sx
I have my first 240 stripped down to the shell except for the wiring and i was wondering what is the best way to remove the wiring harness on it its a 89 hatch? thanks
PapaSmurf2k3
Site Admin
AZ89two4Tsx wrote:The 89 hatch doesn't come with a factory lsd does it? Do any of the 240s? Just wondering.
I don't remember exactly, but I'm pretty sure the only S13s that came with lsd were ones that were equipped with HICAS (Nissan's version of 4 wheel steering). If your S13 doesn't have HICAS, it was not equipped with an LSD from the factory.
AZ89two4Tsx
cool thanks
BB1LOVIN
Hey guys i have a legal question.I know smoging the sr20 can be one thing but i was wondering if a cop pulled me over and popped my hood with an sr20det in it, would i get a ticket/arrested? Could i just pull the VIN number off my ka and weld it on the sr20?
PapaSmurf2k3
Site Admin
depending on where you are in CA, if a cop pops your hood and sees an SR, you are going to get a ticket no matter what you put on it. VIN plates are on the chassis, not the engine. IIRC they are stamped into the block if they have one.
BB1LOVIN
ohhh thanks. so what would the ticket be for? would they crush my car as well?
PapaSmurf2k3
Site Admin
I don't know what those crazy crackers are doing these days. Some say they take your car and make it a police car, some say they crush it... I think something bad will definately happen if they pull you over for street racing... but if its just something routine, probably not. The ticket for popping the hood would be for an illegal motor in your car. Maybe one of the other guys from CA will chime in soon and let you know exactly whats up.
chicagorilla
Car: 95 multicolored 240sx
What up everyone, first post. My noob question is what weight and kind of oil would I need to put im my R33 diff? GL4 right? btw the car is being built as a dd.
PapaSmurf2k3
Site Admin
I've always had good luck with Lucasoil differential/gear oil. I run 80w90 IIRC.
Micho
Hey guys, I'm interested in buying an 1995 Nissan 240SX, which I got a pretty good deal on. However, I'm really confused now after getting home from getting the bill of sale. Looking at some pictures and specs, I realized that the base model is 4 nut 15 inch wheels, but when I was over looking at the car, I clearly remember it being an SE. SE models came with 5 nut 15 inch wheels, correct me if I am wrong. The car was billed and even has a SE sticker on the back, leading me to believe it was an SE. However, now that I think about it, the summer tires the gentlemen was showing me were also in 4 bolt pattern, leading to me now thinking that it is a base model but SE stamped.
The specs on the car: Power window, power lock, power mirror, AC, cruise control...not sure if that helps or not...but I'm really hoping it is a SE model however, the 4 bolts lead me in the other direction.
onemad240
Car: 95 240sx base
MichoIf the s14 has 4 lugs then it is a base model, tell him wtf man? lol I rock 4 lugs too though....fo lug powah!!!
Anyway to anyone who can help me.....I want to buy some arp wheel studs for my 95 240sx, base model btw, and i do not know the part number, or where exactly to buy them from. Lmk thanks-chris
PapaSmurf2k3
Site Admin
I was waiting to see if anyone else answered you but no one did. I don't know if ARP even makes wheel studs. I was under the impression that they were more of an engine stud company. If you want strong wheel studs you can get Nismo hardened steel ones. http://www.courtesyparts.com should have them.
onemad240
Car: 95 240sx base
i apreciate the reply but i was lookin round and arp does make wheel studs but they don't fit the rear hubs for the s14, so yup....thanks for the link
Nali
Car: Datsun Nissan 280ZX
Hey guys Not so Noob noob here, my front bumper is sagging, and i dont know why. I searched the forums 100000 billion times and found no answer.
What could be causing it and why. I started a topic in the 240sx forums in case anyone else has this problem they can get assistance there as well.
Here is the URL: http://i289.photobucket.com/al...e.jpg
the Topic URL is: zerothread?id=323031
MacfromTK
Anyone have any idea why I can't get radio signal? All the normal stations I can normally listen to are just static. So what should I look for while troubleshooting. I don't know too much about radio wiring and stuff. It's a 89' 240sx. Thanks.
dickie
Car: Killer Turtle
if your head unit is aftermarket, theres a good chance someone couldnt be bothered to hook up the antenna wiring. if its hooked up to the stereo, remove the panel in the trunk/hatch area to see the connection to the antenna itself. if everything is connected okay on those ends, assume the wiring is broken somewhere in between.
im assuming of course that your power antenna is fully raised.
Pyrokid
Car: 2000 Honda Accord, 1990 Sr powered 240sx hatchback
Ok, quick question, i have a bit of a mildew problem. My question is should scurb the carpet or just replace the whole thing?
ice_man152
Car: 1990 nissan 240sx
Roommate is getting a 240sx shell for free...has been buggin me to find a kit to change the front end to kouki headlights, he didnt know where to find one so thougt id ask you guys? like prefabbed fenders, might be a stupid question but dont know the first thing about that swap haha
Shift_Kouki
Car: 95 Nissan 240SX SE
Pyrokid wrote:Ok, quick question, i have a bit of a mildew problem. My question is should scurb the carpet or just replace the whole thing?
Unless your willing to use some decently strong chemicals... I'd look into a replacement.
ice_man152 wrote:Roommate is getting a 240sx shell for free...has been buggin me to find a kit to change the front end to kouki headlights, he didnt know where to find one so thougt id ask you guys? like prefabbed fenders, might be a stupid question but dont know the first thing about that swap haha
What year shell is it? I'm taking a leap of faith and assuming that he has an engine that will work in it. -- If its an S14, get: oem style kouki hood, ebay head lights, then source a bumper, turn signals, and a couple fenders (after market may be easier for the fenders).
Pyrokid
Shift_Kouki wrote:Unless your willing to use some decently strong chemicals... I'd look into a replacement.
By decently strong you mean something along the lines of bleach or something stronger, like sulfuric acid?
KA26DE
Car: 1993 240sx ballsout stock
i need insight, ok i just replaced cyl.3 fuelinjector and now it starts but if i rev it up after i let off the pedal it trys to die, and if i drive it and i let off the gas to come to a stop it dies.im pretty sure its not a vacuum leak so im thinking maybe fuel regulator? or pump (car is a 93 hatch de with 130,xxx manuel) plzz help meh
Soravia
Car: 2003 Audi A4 1.8T
I'm planning to buy a Chuki shell with Auto Trans. It's an SE with HUD and Sun Roof.
I want to know how to tell if the car has LSD from sport package. It has aftermarket wheels (crap) and unknown coil-overs.
Thanks
PapaSmurf2k3
Site Admin
KA26DE wrote:i need insight, ok i just replaced cyl.3 fuelinjector and now it starts but if i rev it up after i let off the pedal it trys to die, and if i drive it and i let off the gas to come to a stop it dies.im pretty sure its not a vacuum leak so im thinking maybe fuel regulator? or pump (car is a 93 hatch de with 130,xxx manuel) plzz help meh
Sounds like a vac leak to me... could be a dirty MAF. Chances are its not the pressure regulator, and if the pump was bad... it wouldn't run at all. What is your idle set at? Have you tried Seafoaming the car?
Soravia wrote:I'm planning to buy a Chuki shell with Auto Trans. It's an SE with HUD and Sun Roof.
Thanks
Check for an orange sticker on the diff. Also, if you jack the rear end up, put the car in neutral, and spin one wheel, the other wheel should spin in the same direction. If not, you don't have a LSD. To come equipped from the factory it would need Super HICAS.
onemad240
Car: 95 240sx base
i am running 205/50/17 in the rear and 225/45/17 in the front, should i switch that around? I might be trippin, but it looks like the front have more height, guess cuz of the small width of the 205 in the rear, somebody school me.
