KiMbRoZz wrote:hey guysI just bought a 1996 240sx the gay looking zenki.I want to do a 97-98 front end swap. The questions I have is:
1)When I want to buy and install a kouki projector headlamp, what do I need to do? Is it direct bolt on or do I have to rewire to change to "projector"?
2)Where can I go to purchase a jdm projector headlight? Do they sell aftermarket projectors other than jdm?
3)Is fiberglass fenders a good alternative to OEM metal fenders?
thank you!
1) iirc, headlight wiring will need to be modified to fit the kouki bulbs. Dont quote me on that cuz I dont have an s14 to begin with, but from what I heard, that's a common thing. Hopefully that doesnt seem too hard, becuase it really isn't. All it is, is just cutting the wires you have and soldering the kouki ones in (I think?)
2) yes... there are other companies that make projectors, like Hella for example.
3) sure, why not?
gemballamiragegt wrote:hey all im new here and dont yet own a 240sx but am planning to buy a 1990 or 1991 HB. i want to swap in a SR20DET. how much should i be looking to spend? ive found some sr's on ebay for like 2000-2500. is that a decent price?
yeah, that sounds about right... but honestly, I wouldnt trust getting engines through ebay. Aren't there any shops nearby that you can physically examine conditions? Reason being, if you order from ebay, and they send you a blown motor... regardless if you get you eventually get your refund or not... its a huge hassle..
gemballamiragegt wrote:also, i have been searching online on different sites for some parts that i want to add and want to find out if these parts are gonna be good or not. keep in mind im not gonna be taking this thing to the track all the time, it's just gonna be a daily driver to play with.
Blitz NUR Spec-R CatbackFR High-Flow CatMegan Turbo ManifoldMegan DownpipeGReddy M Spec Intercooler KitInjen Short Ram IntakeMegan Coilover KitMegan Front and Rear Struts
Again, i dont wanna do a complete overhaul on this thing, just wanna make it a fairly decent little drifter to play around with. so any input on the parts listed above would be great. im also putting on TenzoR DC-6 Version 1 rims (the black with red lip). what size should i be looking for? I wanna go with the 17x7 but i have read in some different places that those might not fit. should i go with the 16's? thanks guys.
okay... you say, coilover kit and front and rear struts by Megan. You're talking about their basic coilovers right (streets and track)? not a spring and strut combo? if so.. eh, they're okay. Honestly, I'd spend the extra couple hundred more to get KTS or Stance. Huge difference in comfort, regardless of spring rate.
and what's the injen short ram for? If you're spending more than $50 on a peice of shinny pipe that will probably do nothing to your turbo... then, IMO, its not worth it.
and with the wheels, I wouldnt do 17x7. Stock wheels are like a 6.5" width already... why stick with teh same width? more than the diameter of the wheel, width and offset is more important. If you want 17's, I'd go with a minimum of 9" width, with an offset no higher than +20
