Apex »
https://forums.nicoclub.com/apex-u1438.html
Sun Jan 02, 2011 6:17 pm
So... got spark on all cylinders tonight. Sprayed brake cleaner in the intake and found combustion and fire out the intake mani... promising.
Also, unhooked the fuel pressure gauge and put the line into a plastic bottle. I rolled the key over to listen for the prime. The bottle almost filled with a fuel-like substance. It was brown and cloudy and didn't smell very strong. So... I took it outside and poured some on the ground and lit it. It burned... does that tell me that it would burn in the cylinders (eg. not bad gas)?
So... the pressure is supposed to be 36psi (at idle). When the pump primes, the pressure is 20psi. BUT... when the relay kicks the pump back off, the pressure goes directly to zero. I'm thinking the fuel pressure regulator is prolly bad or not set right. It has to be something between the gauge and the cylinders (line, fpr, rail, injectors). I'm thinking injectors are unlikely because they wouldn't all be bad. Rail; nah... its too simple of a part. Not the line, because its too big to be clogged. That leaves the FPR! It is a Nismo adjustable.
