WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Tue Dec 01, 2009 5:03 am
Do you think you'll need 1000cc injectors? Or was that just a number you're using as an example?
There are tons of turbo choices under $700 that perform really well. They may not be as efficient, but we're talking small percentages and not over the entire map. The BB Cartidge allows for quicker spool, but only by a few hundred rpm.
Those things aren't enough to convince me to spend another $700 to $1000 for just the turbo. Given the same budget I'll take a standard T3/TO4E and with the left over money I'll buy alcohol injection AND nitrous. The turbo is only part of the equation, tuning and all the related support pieces make a larger difference and are usually the ones least considered.
Take for instance the 530@17psi. Sure as hell wasn't done with a SAFC or off the shelf rom tune. To make that much power you are relying heavily on the methanol and ramped up ignition and the ability to tune it precisely. Almost anyone can make 350-400 horse power, thats just adding fuel and boost. You can't help but make power. But making more then 12hp per psi of boost means you're doing more then just adding boost. In fact, to make 530 at 17psi you're making 20hp per psi of boost. Thats double the usual average. There is a hell of alot more involved with that then the turbo selection
I edited this thread, no more crapping in here. If you have an issue, Brianatnicoclubdotcom
WD
