If you are that concerned about hitting the 10's just invest $450 in a nitrous kit. No need for a twin scroll or all the $$$ spent on a true twin scroll mani with double F'in wastegates...lol.
Only use it in 3rd and 4th so traction is a non issue. A 50-75 shot should do the trick if you need .5 or less. Not to mention the cooling affect it has on the intake mani etc.
motoman399 wrote:its about time this thread gets going again. i miss it... lol how are the turbo projects coming along?
that is pretty impressive from the one you posted. 180K miles holy damn:shocked
GL
I dunno about the rest of you guys, but seeing fast passes on high mileage motors gives me a little warm fuzzy inside on the inside. The key is taking care of the motor. If you keep the fluids fresh and fix things when they break, any DOHC motor should run 250k easy.
As far as where I am with my build. The new motor is in, my wiring harness is being redone since rabbits ate the entire harness that goes in front of the damn motor. I'll be getting her up and running 100% NA before I install the turbo. Speaking of turbo, I just got done rebuilding my T04E. I don't mean T3/TO4, I mean full T4. It's got a 50 trim compressor wheel, stg 3 exhaust wheel and a .81 AR exhaust housing. So it's gonna be a touch laggy...lol. That's ok though, I know she responds well to a crapload of boost
I'm gonna try for 350whp by 12psi
WD
