HeavyDuty »
https://forums.nicoclub.com/heavyduty-u10182.html
Fri May 28, 2004 4:38 am
Temps at Moroso during summer are high enough for me to swear not to ever go back to a June-Aug show or race.
The noise you're hearing is from a combination of incorrect pinion depth and lack of appropriate backlash. Or, you could have some damage to the pinion bearing being reused or if a new one were installed incorrectly.
The pinion depth refers to placement of the pinion fore and aft in the housing (front of the car to back of the car). The ring gear backlash is relative to left to right placement of the ring gear (driver's side to passenger side).
It takes hours & hours of assembly, measure, disassembly, adjustment, reassembly, repeat, to get it right. Don't feel like the Lone Stranger, I know it's frustrating, but it takes a special person or a shop with very precise tools & the desire to set it up perfectly to get it right.
When the diff exploded in my Lightning, I took it back three times before they installed a complete new assembly. I know exactly what you mean about the noise, it sounds like a 747 is about to land in the trunk.
You dropped a second and gained 5mph trap speed! Considering what I know the conditions to be right now, I too would have hoped for more, but would be pleased nonetheless knowing I still had my gear to still install. The gear *should* drop your et slightly but your mph might not increase much. Your 2.2 60' is real good! After looking at the videos, the standing start initial rpm climb to 2400 rpm looks stock to me.
In my experience, when adding headers you might lose a little down low for an increase up top.
What size primaries are those anyway? (The diameter of the header pipes at the head.) Hopefully not larger than 1 5/8, hard to tell from the pictures.
Oh yeah, one more thing. If I may suggest, trust the force, Luke, when it comes to shift points. If it stops or slows accelerating, shift then, don't arbitrarily take it to 7300. Next time I would try 7200, 7100, 7000, etc & see if your times don't drop until they start going back up again. Then you will have found the sweet spot.
Even with the JWT ECU, my car stops pulling long before 7300. With your larger exhaust, it should pull up higher, but maybe not quite to 7300.
