Headers, O2 sensors, JWT ECU, & air/fuel ratio question
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Rob.. Your EGR is unhooked, mine is nonfunctional, IE it doesnt activate, its all hooked up and stuff...
1992Q45A
This is the biggest problem with our cars performance
Damn I wish we could drop at least a 5 speed auto in there
The 2k4 XJ8 I drove with the 6 speed auto was awesome.. Same hp as ours, but never felt like it had accel dead spots.. Rockets off the line, always in the power band..
Q45tech
Don't even think of the current 5 speed from Nissan [if it could be adapted to fit]..........the Q would be turning 2400 rpm at 60 mph in 5th, fuel economy would drop by 20% on highway.
Not that much stronger than what we have even more torque reduction at shift and the electronic throttle to decrease power at during after shift.HOWEVER the QX56 transmission is a little better in that they tweeked the first 3 gears. But the span is still pathetic at 4.5887. But at 5360 pounds the engine needs some rpms.
1st 3.827 .....12.85 total torque multiplication2nd 2.368 3rd 1.520 4th 1.000 5th 0.834 reverse 2.613 Final drive ratio 3.357
rsiwicki
Car: 95 Q45T
Quote »I warned them* in 2002 when I first saw the transmission ratios and diff gear ratio.[/quote]
That there stuff about the combo of transmission/diff ratios is some of the best shiet that I have learned so far as it really explains a lot about the accleration rates and fuel economy of many cars with the same HP rating. Now I know why all the car mags have these transmission ratios per gear listed and the diff ratio so that a "rea" tech junky can put them into a spreadsheet and compare with other cars to get some theoretically close "real" stat comparisons between cars.
