THIS IS AN EXAMPLE OF A QUESTION I TRULY APPRECIATE. WE CAN SEE THE PEAK HP IS EXTREMELY HIGH ON THE DYNO SHEET. TORQUE IS CONSIDERABLY LESS. USING THE SIMPLE FORMULA OF BOOSTED HP DIVIDED BY STOCK HP WITH THE HP GAIN COMPARED TO THE PRESSURE RATIO WE SEE:270/135 = 100% GAIN ON THIS EXAMPLE. OUR HIGHEST RUN HAS BEEN 212/135 = 57% GAIN. SO WE NOW ACCEPT THAT 7 PSI IS A 1.5 (50% INCREASE) PRESSURE RATIO (7.4 + 14.7 /14.7 = 1.5). THAT MEANS OUR KIT IS SHOWING MORE THAN A 100% EFFICIENCY IN THE POWER GAINED, WHILE THE TURBO IS CLOSER TO 200%. I AM SURE THERE ARE OTHER THINGS DONE TO THIS EXAMPLE (270 WHEEL HP IS EXTREMELY HIGH ON A TOTALLY STOCK ENGINE WITH NOTHING BUT A TURBO KIT AT 7 PSI), BUT OUR GOAL IS TO BE AT 250 WHEEL HP AND 250TQ @ 7 PSI WITHIN A MONTH BY INSTALLING A PORTED BLOWER AND MANIFOLD, LARGER TBODY, WATER/ALCOHOL GASSEOUS INTERCOOLER, AND LARGER MASS AIR. WHEN BLOWING THROUGH A TBODY THERE IS LITTLE PRESSURE LOSS ON A 60MM UNIT. WHEN DRAWING THROUGH A 60MM, THERE IS A PRESSURE DROP. THE STOCK MAF IS TERRIBLE. I WONDER IF THE TURBO SHOWN WOULD BE OVER 250WHEEL HP WITH A STOCK ECU AND MAF. WE WILL SOON HAVE MORE COMPARATIVE NUMBERS. BTW, HOW MUCH DID THAT TURBO KIT COST TO PUT TOGETHER INCLUDING THE HALTECH--$6000?Bigvinnie wrote:Mr.Knight how will your super chargers compete against FI turbo systems that use larger than T28's. From the majority of your results they carry well in comparison with a great torque range.After about 2500RPM it seems that turbo chargers can infact make more power after low 2500RPM range.Scooter (RBS14) is using 660cc injectors, ITB's, t36 turbo, and a haltech on an all stock block, this testing was at 7PSI..How do you plan on competing with much larger and effecient turbo's on the market, at the price you are selling your super chargers for and what type of upgrading would you have in developement to compete with turbo's of this nature. Last turbo charger I had seen on a KA didn't break 250WHP. As well noted you showed me your calculations on degerdation losses, how does that matter to such an open market with turbo's that have more effecient A/R's than your typical super charger.
HMMM--WE HAVE AB RB20-240 AND A RB25-240 AT SPEEDLAB. MARK OWNS THE RB25. I COULD MAKE A KIT JUST FOR THE FUN OF IT. I ACTUALLY WANTED TO DO A TRIPPLE CHARGED VERSION WITH AN EATON AND TWIN T-2-SMALLS IN A SEQUENTIAL MODE FOR FULL BOOST FROM 1200RPM TO 8000RPM--JUST TO SHOW IT COULD BE DONE :-) FOR THOSE OF YOU WHO QUESTION HOW LONG TWINCHARGING HAS GONE ON, MERCEDES DID IT IN 1939 WITH DUAL ROOTS TWO STAGES @ 24 PSI WITH THE PIPES HAVING FINS ON THEM FOR INTERCOOLING. THEN LANCIA DESTROYED THE RALLY WORLD COMPETITION IN '83 WITH THE DELTA S4, A TWINCHARGED 2 LITER ROOTS/TURBO DUAL INTERCOOLED 585HP 4WD THAT WON 8 OUT OF THE FIRST 10 RACES TILL THE DRIVER WAS KILLED :-( ANYWAY, IF THERE APPEARS TO BE ENOUGH INTEREST IN AN RB KIT WE WILL DO ONE FOR SURE.SeVa-S13 wrote:
Are this argumentative about things in real life, too?
I can appreciate good discussion but get the hell off the guy's nuts already; he doesn't need to defend every single whimsical criticism. Moreover, he doesn't need to. Potnetial customers know about big turbos, some of them don't want one and would prefer a supercharged engine and response; negating acceptable efficiency losses at higher revs.
P.S. - Mr.Knight, how about something for the RB series? I'm probably just daydreaming but the thoughts of a twin charged RB20 make the pants tight.
WE WILL MAKE A CUSTOM UPPER INTAKE MANIFOLD THAT HAS DUAL PLENUMS--ONE WILL CARRY THE EATON DISCHARGE TO A FMIC, WHILE THE OTHER CARRIES THE MIX FROM THE FMIC TO THE RUNNERS. THE BLOWER WILL REMAIN IN THE STOCK LOCATION.Malac0da13 wrote:can you gimme sum feed back SCMASTER on my idea if its feasable...you said about making your kit intercooled...how is that gonna be done...is the SC remain on the same side and have the intercooler shaped like a sideways "U"
They are not, as far as I know; otherwise you'd see tons of GReddy intakes on RB20's, but instead we all go quality race stuff from overseas ($$$$$) or some domestic/eBay hacks (I have an Unstable-Hybrids knock-off and it's laughable).SCMASTER wrote: DO ANY OF YOU KNOW IF THE INTAKE MANIFOLDS ARE IDENTICAL FOR THE RB20 & RB25 JDM ENGINES? THIS WOULD BE FOR AN EATON KIT THAT FIT BOTH ENGINES. IT WOULD BE MUCH BETTER IF THEY HAD THE SAME BOLT PATTERN.
AS I HAVE STATED BEFORE, THIS IS A DISCUSSION AREA FOR THE EATON KIT. IF YOU LOOK FARTHER BACK IN THE THREAD THE DOLLAR FIGURES ARE THERE. AS FOR AVAILABILITY, THEY ARE READY TO ORDER NOW. THE BEST RESULYS SO FAR ON A COMPLETELY STOCK ENGINE @ 7 PSI WITH STOCK TBODY AND MAF IS 212 HP /217 TQ. THE TEST VEHICLE HAS 550CC INJECTORS, A DAUGHTERBOARD, AND HEADERS. WE SAW 3.5" VACUUM LOSS ACROSS THE MAF, SO THAT WILL KEEP US FROM 220/220. IF YOU SET A GOAL OF 220/220 @ 7 PSI AND GET 230-240, YOU WILL BE PLEASED. WE TRY TO ANTICIPATE INCORRECT TUNING, ETC. THE COMPLETE SYSTEMS WILL BE PORTED AS WELL ADDING EVEN MORE HP/TQ. THE REASON WE STAYED WITH A STOCK EATON WAS TO SHOW THAT THE ADAPTERS PURCHASED SEPERATELY WITH A USED NISSAN SUPERCHARGER WOULD OUTPERFORM AN SR20DET SWAP FOR HALF THE COST OF PAYING SOMEONE TO INSTALL THE SR20. THE EATON INSTALLATION CAN BE DONE BY A GROUP OF FRIENDS IN A LONG AFTERNOON. ALSO, ANYONE WHO WANTS TO DRIFT A 240 WILL NEVER FIND A BETTER SYSTEM OTHER THAN A V8 SWAP. THAT CAN NOT BE ARGUED WITH.Chezedik wrote:So bottom line, when will it be ready, and what kind of power will it make, for how much?
Scott is one of the lucky ones. Haltech Sponsors him and the turbo and parts were all kick backs. I believe that whole kit not including the ITB's is around $4000, not including taxes, shipping charges. Suzuki GSXR ITB's any one can piece together for under $200......This particular piece together kit can be cheaper for people using a biki rom other than the haltech.You can go MAffless with the haltech though, biki still doesn't have the program setup for half the features that the Halteh has to offer.SCMASTER wrote: BTW, HOW MUCH DID THAT TURBO KIT COST TO PUT TOGETHER INCLUDING THE HALTECH--$6000?
Actually they are stocker cams and a stocker head no porting was done.It was more to the method of using the individual TB's which alone will drop massive torque numbers since there is less swirl taking place at lower RPM's. The KA is known for massive torque output numbers using the long runner design that it has on it's stock plenum design. I do study fluid dynamics, and from my knowledge the stock set up is great for low end and kills the high end making a sever power drop at valve overlap (making the engine anemic).This is one of the reasons that people go with the ITB setup, it may drop torque, but it will extend the powerband very near and closer to 7000RPM as you can see in the dyno I posted.SCMASTER wrote:THE 271 NUMBERS ARE HIGH FOR 7 PSI, AND I AM MORE THAN EVER CERTAIN IT IS NOT STOCK CAMS AND STOCK HEAD, IT IS NONE-THE-LESS VERY HIGH.
Actually it was driven and during the dyno run cylinder 4 had blown from starvation issues. (Causing 4 to run leaner than the other cylinders from the plenum design (or so that is my opinion)). It was a straight through plenum and not a tapered plenum such as the ones that Ivan (turbo240.com) uses.Scooter doesn't care though he will get his hands on another stock block, and if all fails with starvation to 4, more than likely go with a tapered plenum as I suggested.obby wrote: Also, if I recall correctly, the owner of that setup never got to drive it, as it blew up before he got it(my condolences to scooter).
Well I think you should watch those kinds of words you may piss off alot of the people in Northern Cali that know Scooter. It may just piss Haltech off as well, I don't believe fraud is the word that you want to use it is very offensive especially for those that put alot of thought and pride into there vehicle...This happens to be Scooters work.for the amount of work that is put into it I would highly doubt that for a $150 dyno tune it would be fraudulent.Edit: I also fubared he is using a GT32 not a GT36 as I stated earlier.SCMASTER wrote: AFTER FURTHER INVESTIGATION I HAVE CONCLUDED THE 271 HP DYNO SHEET IS A FRAUD, OR THE DYNAMOMETER IS BROKEN AND GIVING FALSE NUMBERS. HOW CAN I MAKE THAT CLAIM? SOMETHING WAS NOT ADDING UP. THE TORQUE NUMBERS WERE SIMPLY TOO LOW AND THE HP TOO HIGH. THEN IT DAWNED ON ME. THE FORMULAS FOR HP AND TQ ARE INTERCHANGABLE WITH THE ABOVE AND BELOW 5250 RPM FACTOR ALWAYS RESULTING IN IDENTICAL NUMBERS. WHAT WE SEE IN OUR DYNO RUN AND EVERY RUN I HAVE EVER DONE--HUNDREDS AND HUNDREDS, ARE THAT THE FIGURES WILL STILL BE THE SAME AT 5250 RPM. EVEN WITH STAGGERED COLUMNS THE NUMBERS WILL STILL BE THE SAME AT 5250--ALWAYS. WHAT I SEE WITH THIS INACCURATE DYNO IS TQ MEASURING APPROX 168 FT/LB @ 5250RPM, AND APPROX 250HP @ 5250 RPM. THIS IS PHYSICALLY IMPOSSIBLE BY THE ENGINEERING LAWS WE MUST USE TO GET ACCURATE AND FAIR COMPARISONS. UNTIL I SEE A CORROLATED AND ACCURATE DYNO SHEET THIS IS A JOKE AND ADDING MORE B.S. TO THIS THREAD.
