Project "Baller"
meminto
Car: S13 Silvia CA18DECT
Maybe that is the intented way they wanted to phrase it...
If it is a mistake, lol, oh well at least I know its not a copy...
themadscientist
I could understand a hand-made sign for a mom and pop business but a big company? I would be happy to offer my services to all the major parts companies in exchange for free parts.
"mike-san, kore wa ii desu-ka?"
"pft, ah, chigau, baka mitae. Taabo kito onegashimasu."
Apexi used to have a very early AFM piggy back called a Big Flow Controller. It actually said on the head unit "BIG FRO CONTROLLER".I asked the guy at the shop if it came with a hair pick and a Commodores record.
Get a load of this stuff.http://www.engrish.com
mazikowski
Car: 2013 Subaru BRZ Ltd 6MT, 1984 CA20E 200sx, 1981 L28E 280ZX
I know it's an odd way to say it, but I always took "Performanced" to mean something like tuned/honed and "by Trust" to indicate the company (Greddy and Trust are one in the same, yea?)
themadscientist
they are the same.
meminto
Another couple of snapshots, this is the general position of where the catch can will be mounted..
I need to have the bracket welded up but you get the general idea..
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Still going to run power steering I see. Did you modify that bracket? It looks smaller.
bentvalves
Car: 89 Silvia K's
a low mounted catch can as pictured will fill with oil quickly.
I dont have any data, just trial and error.
the closer the catch to the breathers actual height the less blowby it will fill with
BQ.05.TD
Car: ca pulsar
IMO that manifold would look alot better ceramic coated. i had my manifold in the heat wrap for 8months or so and i just drove me up the wall every time i worked on the car. the itch you get drives you bonkers and it was starting to get a bit of surface rust that was worse then normal so i got it ceramic coated and now i am addicted to the stuff lol every thing including my planum and runners is getting doneits good to see that you have used allen key bolts every were looks awesome
meminto
Thanks for that mate, although I am hoping I don't have that much blow by, you can't see it in the photos, but the catch can has a dash 6 outlet at the bottom that will be rerouted to return oil to the sump..
The catch can is also fully baffled, it I had an extra dash 8 bung welded that I no longer require so it will be capped off, you can see it in the photo pointing to the block lol...
R34 - Yep still running power steering, it is very heavy steering with 18x9" on the front, plus this is a street registered vehicle.. Ohh and I did modify the bracket..
BQ - I did consider ceramic coating, however I have found in my research that the process is either performs well or it doesn't, there is no in between. I have used FG heat wrap on previous manifolds and for me it is a tried and tested performer....
The socket head bolts do look good, but are also fumctional, the only issue is you can't buy them in the thread to suit the oil pump/water pump bolts so I am fabbing them up, i also had to fab a bolt for the power steering pump as manufacturers don't make them any longer than 80mm...
Modified by meminto at 1:18 PM 2/16/2009
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
looks better and better everytime I see this thread.
BQ.05.TD
Car: ca pulsar
when you mean it dosent peform well wat do you mean? are you talking about it flaking off etc
meminto
As in keeping underbonnet temps down... I know a couple of guys who have had it flake off after 8 or 9 months or so, but I also know other guys who swear by it..
So it is more of a hit n miss thing...
BQ.05.TD
Car: ca pulsar
ahh k got ya
yer i dont know how well it will keep the temps down. the guy recons 30-40%the FG wrap i had did a pritty good job. i just didnt want my manifold rusting away and i was sick of looking at the wrap and wanted a cleaner look in the bay
meminto
My exhaust manifold was never pretty anyway.. But functional it is, it looks 100% better with the wrap than beforehand..
meminto
Cheers gabby, hows the pink coming along under your bonnet lol...
I check your thread from time to time...
themadscientist
I think I had one of these turbos in my hand today, T67-25G with an 8cm backside, very nice.
meminto
Nice one, yeah mines the 10cm version but same deal.. lol
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
Baller status indeed, very clean!
ca18detgabby
03 Infiniti G35
meminto wrote:Cheers gabby, hows the pink coming along under your bonnet lol...
its sitting very neglected in my bfs garage.......
just moved into a new housespent all last week on a cruisehave a G35 that is a gas whore....... and I encorage it.
so the S spends a lot of time just chillin..... have a set of wheels AND two drag wheels waiting to be slapped on..
meminto
Bummer on the neglect lol
Yeah I need to source some othe wheels and m/t's than my 18x10.5's for the strip...
But all good, I chill too much hence the time on putting my shyte back together lol...
DJButton
Car: 2010 Nissan 240sx
Good lord just found this thread. I was unaware that CA could look so fresh! Perfection!
meminto
Cheers mate
lol, I have spent many a night thinking about everything, then I realise there is something else I have forgotten... I tried to make it as fresh as could be...
hydra
Car: 1992 200SX S13
Meminto,Have you considered using an auxiliary vacuum pump for crankcase evacuation? Benifits include better ring seal/less blow-by, as well as greater effective BMEP on the pistons from as little as 5" H2O depression...
meminto
No I haven't, might be something to consider.... cheers
meminto
Starting to look like a motor again...
Finished off the lines, need to buy some clamps for the silicone...
Cheers...
r34 gtr
Hawt! Get it running already so I can hear it!
wynnEZ
Car: 90 240 CA POWA!
Everything is looking real nice!
bentvalves
Car: 89 Silvia K's
the inner diameter of the valve cover breather is more approximate in size to a -10 than a -8.
I would think a motor of this caliber breathing as hard as it will could benefit from something even larger than factory.
meminto
Thanks for the advice...
DJButton
Coming along great!
