Project "Baller"
themadscientist
My cams are only 264 but they are 9.5 lift. It is my hope that that lift, combined with the manifold will allow a slightly larger than streetable turbo act proper at cruising speed and still move plenty of air at full scream. I am not building a dyno queen nor a true race car so I need some responsiveness but on those rare occasions when I find a soda can driver with an attitude next to me I would like to know I can slap that smile off his face with relative ease if I chose to.
zero_gripS13
Car: soon to be 95 s14 hopefully
lots of lift short duration makes for good cam from my research :P hope it works well...
meminto
Car: S13 Silvia CA18DECT
Cheers for that, but I dont use a T based flange, so I am unsure if your example applies.
Its a mitsubishi flange...
themadscientist
I have these sitting on the shelf frustrating me. Too small for my power goals one by one but just rediculous like this!
hydra
Car: 1992 200SX S13
Meminto, I know that you're using a Greddy T67 turbo, my whole point was that you don't need to know the A/R of your turbine housing since you already have the "A" handy... Once again, turbine nozzle area is a much more meaningful indicator than A/R...
As an aside, what turbine wheel have you got in there? TD06, TD06H, TD06SL2, etc..? (is it the 61mm inducer turbine wheel, 65mm, or 67mm?)
meminto
Looks like 61mm from the verniers..
The compressor exducer is 78mm....
Modified by meminto at 8:41 PM 1/25/2009
bentvalves
Car: 89 Silvia K's
glad you see it as that.
If I came across wrong, my apologies as well. I really dont think I did though, and it was a valid enough point for you to salvage an old knackered pulley in the oven....I got you thinking, and thats what these boards are all about, right?
what has me most excited about this build is the RB inake/exhaust valves, Im really excited to hear this motor.
1.8turboterror
Car: 1989 240sx with a built ca18det
Wats up bro I jus love your engine build, If you could tell me what valve retainers you are running. and also wat type of cams and their specs thank you mucho mucho. and where I could purchase these retainers;)
meminto
I use supertech RB25 Titanium Retainers... For peoples benefit, here are some measurements..
Diameter:
Stock = 26.83mmSTRB25 = 27.34mm
Height:
Stock = 7.54mmSTRB25 = 7.54mm
They also replicate the slight chamfer in the base, it would be difficult to get a photo it's that fine...
If you are looking at buying these, email the supplier first, when I bought these they were part of a kit and you couldn't buy them seperately...
Here are the photos, pretty obvious but... OEM brand new retainer on the left..
1.8turboterror
Thank you very much man . Did you order directly from supertech?
meminto
Nah I bought mine online through ipp...
ser20det
Car: Silvia K's 88
meminto wrote:I use supertech RB25 Titanium Retainers... For peoples benefit, here are some measurements..
Diameter:
Height:
So if i'm not wrong the rb25 retainer is for dual spring ? Do you think it's possible to install double spring and retainer on stock CA Valve ?
meminto
Correctish, it's sold with the dual spring kit, but I dont see a problem if someone wanted to use the retainer on a stock spring/valve combo (although it probably wouldn't be warranted)..
However, to answer your question, it would be possible to use double spring with a stock valve, just make sure it's in good work condition... I really couldn't see a point of failure in doing so... However my spring seats are also the ones that come in the kit..
Here some more measurments for people of the valve spring, unfortunatley I don't have a brand new stock spring..
Diameter:
Stock = 26.86mmSTRB25 = 27.59mm
Height:
Stock = 43.15mmSTRB25 = 41.81mm
I know the coil bind on the dual spring is 14.1mm, I am unsure of the stock spring..
Modified by meminto at 11:45 PM 1/30/2009
1.8turboterror
What cams are you running in this motor? and what are theirs specs duration and lift?
meminto
The cams were made for my application..
I provided the info a couple of pages back, however:
Lift = 13.1mm (516 thou)Duration = 261*
If you are considering sticking with stock valves, you cannot obtain that lift height with a stock valve...
meminto
I am having a few delays whilst I settle into a new job, however I have dummied up a few more things..
You can see there is going to be a little interference with the water hose and the alternator. It looks worse than it is and I already have a solution...
Cheers
1.8turboterror
O wow thats some serious lift. I really think you are going to making power past 9500 rpm my dude if you allow the tuner too take it up that high on the dyno i dont see why you wouldnt this engine is very thoroughly put together . quote( I will be happy to stay in the 81-8500rpm bracket, but 9000rpm, will be the highest I will allow...) What is going too be the intended use of this vehicle ? Just a sick as hell street car thats going to see the track occasionally or what?
meminto
Street trim, with occasional meets, track days, jamboree's etc... more of a social thing rather than all out competitive...
1.8turboterror
Im sure your car will be the center of attention at these meets wit ur set up for sure my dude.
meminto
Not a great deal of progression this week, however I now have all the bits in at the fabricators to finish off. I have pulled apart the xf throttlebody to give it a good clean up, but need to have a couple of -10 bungs welded to it for the air regulator and IAA gear.
The throttle body itself looked like it had sat around for a while, there was a lot of grime on the butterfly plate, so I took to it with the buff lol... Buffing is something I seem to be getting quite good at now and have developed my own process...
Here are some before and after shots... I havent started on the tb itself, will do once the welding is finished off.
Enjoy... :D
themadscientist
Hey, I can see myself in it, AHHHRGH
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Daaamn! I didn't know they could be so clean!
meminto
Neither did I.... I have never seen a throttlebody so filthy and built up with scale lol...
It was that smooth that it kept slipping out of hands on the buff and hitting the box behind the grinder lol... After two or three times of that I decided it was enough...
themadscientist
OCD much?
r34 gtr
themadscientist wrote:OCD much?
Coming from you that is hilarious.
BQ.05.TD
Car: ca pulsar
hey mate where did you get that CAS bracket and the backing plate from? was it a guy on nissan silvia with a maroon 180is he still selling thesecheers justin
meminto
Yeah his brother...
http://www.growly.com.au
themadscientist
I don't see the gears in this pic listed on the site, what is the story on those?
I was enamoured with your CAS bracket but I thought a buddy made it one off for you. It never occured to me they were commercially available, now i want one!
meminto
Manifold is finally on, bolted all up today..
I am going to polish the compressor housing, but wanted to get it all bolted up so I could continue on other things, I found some affordable wiggins type clamps for the intercooler pipework and the compressor housing inlet so I can start designing the dual z32 afm intake setup..
Not far off now, got a couple more things to do but should hopefully have the motor in the car by end of feb..
themadscientist
I just noticed the housing says "performanced by trust".The Japanese never cease to amaze me. Check the english if you are going to actually cast something that says it!
