Project "Baller"
meminto
Car: S13 Silvia CA18DECT
I have responded to your email
meminto
Yep its a pnt_performance manifold, fitment was good but my engineer dowelled it all up and match ported....
DALAZ_68
Car: 90' 240sx CA18det
meminto wrote:Yep its a pnt_performance manifold, fitment was good but my engineer dowelled it all up and match ported....
NICE
does it come wiht the fittings or did u have to by them? were they 1/8 npt ?
meminto
No I had to buy fittings, the smaller threads are 1/8 bsp...
zero_gripS13
Car: soon to be 95 s14 hopefully
question regarding your fuel setup...
with running what appears to be a standard 255 feeder pump (correct me if im wrong) wouldnt the 2 larger pumps drain that tank faster than the feeder pump can fill ?
meminto
Hi, I have calculated requirements and it will be fine... cheers
Finished off a little more today..
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
I can hardly wait until it is running and slaying people at tracks of all kinds.
bentvalves
Car: 89 Silvia K's
dang looks sweeet, cant wait to see what it sounds like, I do hope you post a vid.
-8 AN welded to the valve covers right? How come you've stepped up to a -12 en route to the intake plenum, when the -8 will bottleneck its breathing capability?
meminto
Cheers I will have vids of the dyno tuning to start off with..
Not at all, the pcv valve internal diameter is much smaller than the dash 8 size (similar to dash 4 id), the dash 12 was required to suit the outside diameter of the pcv valve...
meminto
Finished off some more this week, dummied up the exhaust manifold so i could get the correct angle for the turbo.. polished and dummied up a few other things..
Cheers
DALAZ_68
what type of oil cooler adapter is that...soooo pretty
meminto
Its an omori oil filter relocator... I am plumbing an external oil cooler in...
But i gotta powdercoat a couple more things, including the filter mount..
DALAZ_68
i might just pick that up ...part number?
meminto
No idea, I got it from yahoo japan... the only numbers are
On the block side: P-150D TICOn the filter side: P-153 TIE
meminto
Here is a dummy of the turbo position, I will also rotate the housing...
r34 gtr
Looks delicious, but is that turbo really going to be good for 720bhp?
bentvalves
Car: 89 Silvia K's
is that a new harmonic balancer, and did you powdercoat it as well.
meminto
Nah I powdercoated the balancer as well...
Turbo should be big enough, but the turbo is not the only component to consider..
hydra
Car: 1992 200SX S13
when you blow nitrous into the compressor inlet, the compressor map is shifted to the right - effectively making the turbo larger...
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
dear god that is freaking hot. who needs p0rn? just open this thread and bam.
bentvalves
Car: 89 Silvia K's
meminto wrote:Nah I powdercoated the balancer as well...
you baked a 20 year old rubber filled balancer in an oven around 400*F?
dont take this the wrong way but a build of that caliber should be sporting a BRAND NEW oem balancer or one like in the group buy going on.
meminto
Nah its cool, but there is absolutely nothing wrong with it...
If there was a problem with doing it, not only would my engineer have mentioned it, but the guys that powdercoated it for me would have said something too, they powdercoat all sorts of engine gear, inlcuding balancers...
I dont want an aftermarket pulley... I have no need for it...
Modified by meminto at 9:32 PM 1/22/2009
DALAZ_68
ca18detgabby wrote:dear god that is freaking hot. who needs p0rn? just open this thread and bam.
gabby is right...ohh so right
themadscientist
You're such a guy Gabby.
LEE_08
Car: Ca18det powered N13 pulsar & Ca18det powered datsun 1200 ute
because meminto & i live in Australia & ross balancers are made here, it is actually a hell of a lot cheaper for us to buy one straight from Ross than in the group buy!
I can get one for $ 368 US and sell it to you for $400 us and it would still be cheaper than what u will get in ur group buy
bentvalves
Car: 89 Silvia K's
meminto if you havent balanced the rotating assembly from front pulley, to clutch pressure plate.....PLEASE consider a 350.00 balancer already!
you spent lavish amounts of money in other areas I.E AN fittings, and they do nothing from a performance perspective.
the advice that lots of people have to offer benefit their pockets in the end, not the end user, remember that.
I've had my engine builder "engineer" tell me without a 3 angle valve job on a certain build and I would be wasting my time as they would never seal....18 year old sr20. I took it home and lapped them in, the marks it left in the face of the valve and the seat told a different story. I saved the owner 400.00 and it had awsome compression to boot.
meminto
So what is wrong with my balancer? Seriously, tell me what is the exact issue that I will have, that you have personally have experienced? I want proof!
And yes my entire assembly has been balanced already...
I appreciate the advice, but I have no conclusive evidence that my balancer is going to cause an issue, I called a number of powdercoaters yesterday afternoon and asked the question, just to make 100% sure...
The answers I received were, "We have powdercoated harmonic balancers for a number of customers without issue"
I bought the AN fittings so I wouldnt have to change a hose for many many years, they look good, and for the ease of changing them if required...
bentvalves
Car: 89 Silvia K's
you misunderstood my AN sentiment, I love them and have them in a bunch of places under my hood as well.
because you have already balanced the rotating assembly, I will stop trying to encourage you to get a new pulley. I still stand that a build of this caliber, with brand new rods, pistons, bearings....everything above and beyond in terms of quality and thought - would warrant a new oem pulley.
If the rotating asembly had not been balanced, I would continue to try and sway your decision
meminto
Hi no worries mate, all good
I get frustrated with people telling me what I should or shouldn't do without factual evidence or data to support the argument...
Aftermarket balancers for the CA are only relatively new in the industry... I have no idea how the ross balancers perform, what the quality is like, they havent really been tried and testing throughout the community..
As I don't really require one, I still did not want my motor to to be a gineau pig for this type of balancer...
themadscientist
mine can be.
I am building something of a similar level, I have already sunk several thousands of dollars into the project and I will be bolting a ross balancer to mine. My crank is balanced to itself, I did not balance it with the flywheel as the twin plate's weight will change as it wears so it seemed a short term return on the investment. The balancer should handle any vibes that might cause me. Each cylinder's package of piston, rod, rings and bolts will be brought into balance with the other three to retain the rotating assembly's balance. I have dropped a couple hundred bucks on the laboratory-grade scale to do it. I plan to have a motor stable to 9K and it building with that in mind.
