Doesn't some company in Japan make an injector that actually injects two separate streams just to resolve that issue? It seems kind of like a bad idea to me...buffy wrote:You are correct float. The injectors fire direclty at the wall seperating the two ports.
It's not bad if you've got the butterfly's hooked up correctly and working. They really do help out with the bottom end of the powerband.buffy wrote:I can't see how it could possibly be worse than the 8 port head which has an injector firing at one valve per cylinder.
woohoo, back flip, back flip.ISL33P wrote: they should be ready by the end of next week.
cool, I think Buffy may well wet his pants when he reads this....nice one mate..ISL33P wrote:no, im fine. i'll work with what i have. they should be ready by the end of next week.
yep, that's what i was going to say.Long runners help low end torque, not entirely sure why without getting books of the shelf, probably some odd resonance/pulse thing.Limpan wrote:They are made to meet a special goal. He´ll loose a little high end, but gain alot at lower rew´s. just when the turbo bost is high.
You're spot on my friend....Jezz_s13 wrote:probably some odd resonance/pulse thing.
