Jeffers_S13 »
https://forums.nicoclub.com/jeffers-s13-u24675.html
Mon Jan 17, 2005 1:54 am
Hello all !
After weeks of searching I have finally discovered this thread and registered on this forum, Cortina Mk1 is a familiar name, Im in the UK and spend a lot of time on the SXOC.COM forum.
This thread and the project it covers is of great interet to me, the design you have come up with is very similar to one that I have had in mind for some time. I have found only one site covering a custom made inlet although it was for an SR20 on which I was basing my design. I can send pics if you like, I forgot the link but saved the pics, it may be useful for your next project ? It has a longer neck before #1 inlet and also a curved rear and a subtle inflexion at the side to create a kind of scooped vacuum effect to 'save' air for number 4, pics would help more than words...it also uses ram pipes, but from the pics I have it looks like the guy made #4 much shorter, not sure if the guy did any flowbenching to prove the design.
Anyhow, the reason I need to make a custom inlet is for a kit car project Im working on, where the OEM inlet will stick up through the bonnet, Id rather keep the bonnet as standard to avoid ugly bumps and bulges so am planning on going down the custom inlet route. After looking at what I can ditch from the inlet, it is easy to tidy the whole look of it, as I wont need brake vacuum and the water heating for the TB and the rear will be ditched. The only thing that I was planning on keeping was the AAC valve set-up, but on this thread it has been said it can be ditched aswell ? how so ? I assumed you'd be using a TB and an aftermarket ECU to control it but it seems no ? can you or anyone elaborate on how to move it to the firewall ? I guess two pipes could be run from it, has this been done before is this how the GReddy one works or is it mounted to the manifold like the OEM one ?
Also, would you mind letting me know what thickness aluminium you used, I was planning on using 3mm as I have an abudance of the stuff and any thicker tends to crack when bent.
And, is there a newer thread than this that I have yet to find ?
Thanks
James
