Custom Plenums (intake manifolds) for CA's
fanta
ISL33P wrote:these are the sacrifices that need to be made to take full advantage of the plenum.
Indeed, just wanted to verify
slw240sx
Car: 1990 Ca18det 240sx Hatch
AAC is required to alow the car to idle. but you could relocate it to the firewall and run some 3/4 heater hoses into the plenum and into the IC piping.
ISL33P
Car: VH45DETT powered
if it is as simple as that it can be sorted out and fitting put on the plenum to support the aac.
P.S. still no reply from website owner ?? i am keen to sort something out.
Modified by ISL33P at 11:20 PM 10/17/2004
ISL33P
just another photo with the plenum installed on my dummy block
datsunboy
Car: Datsuns
can someone send me pics too? I can't see any attatchments on this board at all...if anyone knows how to fix that too???
cortina-mk1
Car: GT-R Skyline, MK1 Cortina's
pics work fine for mehas it been disabled in your user options somehow ??
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
hey, im kinda curious to see this. i dont have the money now but maybe if all goes well i can afford one in the not too distant future. if you could email the pictures to me at [email protected] it would be great.
its good to see more and more people making parts for this engine, its becoming quite a real contender compared to when i first got it.
- tim
buffy
How much would you be able to send these to the UK for?
IBOO57
Car: Datsun 1600 P510
I went over to ISL33P house last night to have a look at his Plenums and can tell you that they are a good job with excellent welds etc.
cortina-mk1
@buffyhes posted before weight will be about 5kg
the cost would depend upon how you wanted it sent sealmail, air econ, air express or fedex.
check here for pricing on international freight http://www.auspost.com.au
buffy
Going by that economy air to UK is $86.50
What is the final price of the plenum? I may want 3 of these
What size throttle body do you propose to use with this plenum?
ISL33P
final price has not been determined but around $US450 or $AUS600 plus freight. if you buy 3 or more we can sort something out. email me [email protected]
throttle body size depends on the cars main use. street/drag/dyno i would recommend a large throttle body 60mm+ and for circuit use i would recommend something like a rb20 or something around the 50-60mm to keep throttle response up.
gtr i have sent you some photos.datsun_boy i just sent you the photos which are on here
CA19DET
Sorry guys this forum sux arse now, i cant see the images either and i dont have the option in my controll panel off. so i dont understand why...
but anyway please send me the pics or host them online somewhere...
thanks
ISL33P
i am dropping a std head along with the std and custom plenum for flow bench testing tommorow. will have results by mid next week.
ca19det - i have sent you the photos
DriftinNC
Car: Sr datsun 510
the reason why you cant see the images is becase of your server, try going to the website http://www.nicoclub.com then log-in and see iff you can see the attachments....thats what worked for me
CA19DET
thanks for the photos,
float_6969
Yea, if any of you are still using the http://www.nissaninfiniticlub.com site, switch to the http://www.nicoclub.com site and see if that helps.
iliketocrash
yeah. i was using nissaninfiniticlub.com site and i couldn't see anything. i switched to nicoclub.com and everything cleared up and now i can see attachments! yay!
ISL33P
gbot the results back for the flow bench testing. spoke to the engine builder and he recommended to not include the head for the test (mainly due to not knowing the exact condition of the head since it came off an engine which had a very tough past life, two broken ring lands and valves on the scrap side of things) but to test it the same way intercoolers are tested for flow. the results were very surprising and impressive.
- standard manidfold flowed 343cfm at 25 inches - custom plenum flowed 555cfm at 25 inches
this equates to a 62% (61.8% to be precise) gain over the standard manifold. not bad for my first attempt.
i am going to see the test vehicle tommorow to sort out the final installation and dyno results will be available soon thereafter.
KaZ (VaBch)
Why is it that whenever I friggin load an attached image, it says this crap:
"ErrorFile attachments can only be linked from the message board server; Outside linking is not allowed.
Your referrer: http://www.nissaninfiniticlub....86596"
It always works otherwise... (img links etc). Argh... I wanna see... =(
nocwage
Which throttle body did you use?The stock CA18DET one or the larger KA?
Nunook
Im interested to kno how the power/torque is down low and mids?
biosehnsucht
KaZ (VaBch) wrote:Why is it that whenever I friggin load an attached image, it says this crap:
Same when I'm at work but at home it's fine. It might be some freaky firewall/proxy settings somehow..
cortina-mk1
@isl33p,im interested to know how each runner flowed? how even they were?it sounds like it was tested from across the whole four ?
ISL33P
used an aussie ford throttle body, measure 65mm internal diameter.
cortina-mk1 - i was going to pick up the plenum on monday but i may get him to do another test to see how each cylinder flows. yes the test was carried out over all four.
i'll let you know how it goes.
cortina-mk1
so did the tester blow throught the throttle body intake and get the readings from that?
ISL33P
im not too sure, ill find out all the details tommorow and get back to you.
this is the first time i have had a plenum tested and i am still figuring it all out.
float_6969
!!!!!GUYS AND GALS!!!!! QUIT USING THE http://WWW.NISSANINFINITICLUB.COM SITE AND START USING THE http://WWW.NICOCLUB.COM SITE. IT WILL CURE YOUR IMAGE PROBLEMS!!!!! (Sorry, I'm tired of saying it...)
iliketocrash
why not just make a sticky with the title "Forum Issues" or something so all the new people can read it too or something?
ISL33P
complete results with individual runners tested will be available by the end of the week of start of next week.
dyno results are about 3-4 weeks away.
