ISL33P wrote:
terminator - can you please send me a picture of the tb flange showing exactly where the tb bolts are located, including measurements for the bolts and the flange itself.
Modified by ISL33P at 7:22 PM 1/27/2005
At the moment the only pics I have are what's no the ebay link in my post..but I'll pass this on to someone who might be able to help.
just got this back from Simon Norris hope it helps you...
80mm Q45 Throttle body flange is 102mm square OD with a 83mm hole in thecentre. Thickness should be approx 10-12mm to ensure adequate strength. Mounting hole PCD is 106mm (centre to centre measured diagonally across opposing holes). If measured between each hole in a straight plane then the distance is 73.5mm centre to centre. Each mounting hole of which there are four should be 9mm clear in diameter. Cheers Simon
Modified by Terminator at 6:20 AM 1/27/2005
