Cube DIY Articles
Home of the Nissan Cube forum and CubeDriver.com
krimsonviper
2006 Mazda 3i Sport -Totaled
1989 Nissan S13 -Sold
1990 Nissan S13 -Sold
CBURKE
Car: 2012 Nissan Sentra SE-R Spec V!
Shift knob change!
You will need:
10x1.25 thread cutting die
Cutting wheel
You will need to cut your stock knob off unless you are some kind of monster body builder and can just pull yours up and off!
Tool for the job!
CUBE by cburke.industries, on Flickr
I did this so I could see where I was cutting so I didn't hit the shifter
Cut!
This is what is really holding the knob on.
You can see the teeth in the shifter!
Ok, time to make some threads!
BAM!
I used a 2" shifter ext that you can buy off Ebay. I like haveing my shifter up high but it also helps with the rev. If you do not want to use an ext then you will need to trim the rev top so it will not hit the new knob.
Have fun!
Paul79UF
Car: 2011 Nissan Cube
Here's a few of my DIY Guides -
Nissan Cube Tail Light Bulbs Replacement
Nissan Cube Head Light Bulbs Replacement
Nissan Cube 1.8L Oil & Filter Change
Nissan Cube Cabin Air Filter Replacement
Nissan Cube Front Brake Pads Replacement
Getting to the tail light bulbs and also the cabin air filter were both more tricky than I had expected. I couldn't believe that you have to remove 9 screws just to drop the glove box. Once you know how to do either procedure, it only takes about 5 minutes more to complete than on other cars.
ronsweden
Car: 2013 Cube 1.8SL
This is my second post in two years. Got sidetracked, bought a Sonata, stuff happened. In any event, I hope this is the right place to post this. I got a billet grille set for my 2013 Cube. Top grill was easy. Middle slot instructions said to take off the "cover" that was under the car (five bolts and just as many clips.) Nonsense! I had a friend take a look. He inserted the grill, reached up behind it, latched the L-shaped hooks on, and while I screwed, he held the lock nuts in position with a pair of pliers. Thanks. Ron
Return to “Cube Forum”
